that have had the opportunity to install an SR20VE, did you happen to notice if you can use the DE alternator, water pump on the VE engine? There reason i'm asking is because the VE engine that I'm interested in apparently does not have these items and i'd like to know if I could swap these items. TIA
Like Charles said you can use the DE alternator. In fact you have to use the DE unit if you plan to run a HS header. The VE alternator is larger and interferes with the HS header.
Never bothered to look at the WP but I suspect it'll bolt right up.
I am having a similar problem. The engine I am looking at does not have a MAF Sensor. I have heard that the MAF on the VE is identical to the one on the Frontier.
Originally posted by RallyKid I am having a similar problem. The engine I am looking at does not have a MAF Sensor. I have heard that the MAF on the VE is identical to the one on the Frontier.
I know the configuration is the same but not sure about the the voltages.
