Old 06-01-2002, 05:28 PM   #1 (permalink)
B15 SR20VE Swap
Would it be as easy to swap a SR20VE inside a b15 as it would on a b14? I heard the b15 sr20de is almost as similar in design as the sr20ve. What would I need if I did get the SR20VE? I'm really interested because I'm coming up with some cash soon and it's either sr20det or ve.... Thanks
GQEmer is offline   Reply With Quote
Old 06-01-2002, 06:10 PM   #2 (permalink)
Track addict
Go DET and save yourself some headaches.
Jim Schumacher
My 240
Shoes59 is offline   Reply With Quote
Old 06-01-2002, 06:13 PM   #3 (permalink)
Re: B15 SR20VE Swap
It will fit just like any other sr20det/de would fit. What would be hard is the ecu. I saw this new standalone system called SDS That might be worth a try rather then fool around with a ecu conversion for a JWT ecu. My local shop charges 1400 for the SDS and tuning.
Steve
Old 06-01-2002, 06:17 PM   #4 (permalink)
Jim, I'm not feeling the love anymore. You lost that lovin feeling?
Steve
Old 06-01-2002, 08:47 PM   #5 (permalink)
Track addict
Not at all. I just think the majority of younger guys contemplating a swap would be much happier with tire smoking, tranny breaking power and the relative ease of going turbo vs. VE.
Lets face it, parts for the VE are hard to come by, ECU tuning is still not proven and the fact is I'm getting tired of hearing the same questions over and over again.
BTW, I scheduled my tuning session with Yoshio on Thursday June 20th. I'll be there for the day and then heading over to Mosport to run with Trackmasters Fri, Sat & Sun.
Old 06-01-2002, 09:05 PM   #6 (permalink)
Great news. I know you will tell us all about it. Looking forward to hearing from you. Good luck.
Steve
Old 06-01-2002, 10:38 PM   #7 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
So which one would I use for a B14? The EM-3 right? The ignition on the SR20Ve has a distributor. I think this might be easier than the current ecu's available. It also seems like it has optional add on's like RPM switches (use it for the valve timing).
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-01-2002, 11:24 PM   #8 (permalink)
All correct. You lose the VE distributor. The whole thing from what I understand runs with a map sensor, throttle position sensor and a temp sensor. You program everything else. Not a DIY project for tuning. Need a dyno. They do give a a base program to get the car started. This is all I know.
Steve
Old 06-04-2002, 09:54 AM   #9 (permalink)
1 mean BEEP
I have to agree with Steve all the way. SDS will save a lot of time and money. I will be running SDS on my Turbo SE-R. If any of you guys are intersted in getting SDS install you can call the shop BBA at 757.424.0200. Its only 1400 installed you can't beat that price.
Alex
Turbo SE_R
Commander Lex is offline   Reply With Quote
Old 06-04-2002, 10:36 AM   #10 (permalink)
W11 NX since 02
If the kids want tire squealing,tranny breaking,uncontrollable power get a mustang or a DET........
Mndgy is offline   Reply With Quote
Old 06-06-2002, 04:01 PM   #11 (permalink)
The Serbaninator
OK
1) If you want Swap info. check out www.b15sentra.net and look for Trav4011.......he swapped a DET in his B15......its a lot harder than you think.....and stand alones are not always the best choice either..............
so take a look there, search thru the DET swap info and stuff, and ask questions. A VE in a B15 would be sweet indeed...........
2003 Redline 350z Enthusiast 6MT bb 60-1 inside
My Webpage, New Domain Name!
1994 4runner SR5 4x4 offroad daily driving beast!
chimmike is offline   Reply With Quote
Old 06-06-2002, 05:15 PM   #12 (permalink)
1 mean BEEP
Dude in my opinion I think what SDS is the easiest Stand Alone you can install. I had so many problems with JWT ECu that I just went SDS. Some people have had a lot of luck with JWT I havn't. I think that since JWT has not made a good image for the ECU that any doing a VE swap should try it. In my own opinion.
Alex
95 Turbo
Old 06-07-2002, 12:31 AM   #13 (permalink)
Alex
95 Turbo
I am having good luck with mine
TurboJesus is offline   Reply With Quote
Old 06-10-2002, 12:36 AM   #14 (permalink)
The Serbaninator
none of you have OBD II 32 bit ECU systems in your cars.
the B15 is MUCH, MUCH more complex.
go here: B15sentra.net, the ultimate authority
and seach under SR20DET swap and Trav4011 for a TON of info........and if you want more, post and ask for info on it.
Old 06-10-2002, 03:03 AM   #15 (permalink)
thanks for the suggestions.... I really, really, really want the sr20ve... as much as i want turbo.. the mpg would suck... My bro has a heavily modded gts and even with all my mods Hotshot CAI, Hotshot Headers, HKS Catback exhaust, UR Pullies, Flywheel, and Clutch... still can't hang with him. I gotten a 15.1 at the track this past weekend.
2.225 60ft
6.320 330ft
9.698 1/8
73.16 1/8 mph
15.113 1/4
90.06 1/4 mph
thinking of getting the s3 cams.. but i'm coming up with the money and just druel over the 187 hp and vvl.. like i said my bro just hands my ass to me every day... and i need some payback... well I'll just keep dreaming... I'll see my options.. but thanks guys
Old 06-10-2002, 01:30 PM   #16 (permalink)
BTCC VE Power
Contrary to popular belief, MPG actually stays the same and sometimes goes up. The reason it goes down is because when you got turbo in your car you wanna boost a lot, especially when you first get it.
If any turbo owners are out there wanna fill in with this info...
DOnt let gas milage stop you, cause thats the least of the expenses involved with a turbo car.
Old 06-10-2002, 10:19 PM   #17 (permalink)
爆走
mpg
mpg goes up in most cases. most of the sr20ve`s are getting 25-27 mpg. turbo also gains gas milage because youu are producing the same hp/torque at a lower rpm which yeilds better mpg untill you crank the boost so hi it starts to go down because of the massive conumption of gas. anything that lets your car breath better usually means you are running more efficiently. thats why you would get more power out of the same displacement(best example is NA). turbo does the same thing as long as you stay in a happy turbo efficiency zone. if you put some wider, longer gears on a turbo car you would see more mpg at higher boost. because you make more use of the power that way. less is wasted.....but who wants a big turbo for fuel economy anyway....? silly people turbo`s not for the environment its for POWER!! hehe.
Old 06-10-2002, 11:11 PM   #18 (permalink)
Team Tool
Re: mpg
HAHAH Yeah do you want good gas milage, or do you want to hand your bro his ass!!
Jackson Diamond is offline   Reply With Quote
Old 06-19-2002, 02:32 PM   #19 (permalink)
Designated Driver
Ok, this topic has gone from VE to DET and back to VE talk again... let's have an overall impression...
If we want major power with our B15's with the OBDII, what should he go with? VE or DET? Is a VET possible? FWD of course...
The VE has been talked of as similar and not needing too much to modify but the ECU... The DET is the almost the same actually...
We need to get a full summary so we know what the best route is...
Cost: VE or DET cheaper to get in there? And which is more expensive to upkeep say we GUN the car alot.
Efficiency: MPG, which is better?
Emissions: Both pass?
Power: Which has more power?
At the same cost I'm willing to go either way, leaning towards the VET for fewer turbo hassles, MPG, and emissions... But of course everyone will ask, "why didn't you go with the Turbo?"
01 B15 SR20
93 RPS13 KA24
Mad Sentra is offline   Reply With Quote
Old 06-27-2002, 09:44 AM   #20 (permalink)
French Sentra NUT
Im also leaning towards the VE.
First off, price seems similar. Initial cost for the VE is expensive, but remember, no turbo timer, IC, Piping, rebuilding of turbo, etc...
Also, slap the engine in, get Electronic engine management, SDS/JWT whatever, and you should be done right ?
Its as simple as it gets. I know for use B15 owners, there is some wirring to be done with the harness, but thats expected with anything, maybe simpler with the SDS actually.
Also (Jim will be happy about this, hehe) I dont want/need HIGH torque, tire burning powah.
Im a road course guy, and also might want to run in Sedan GT here in quebec next year. a JDM N/A engine is acceptable, turbo is not.
Oh and lastly. I can buy a cheaper SR16VE, and use my B15 SR20DE to stroke it
http://www.spicez.com/img/B15.jpg
Nissan Performance Club
"Go Slow to Go Fast!"
spicez is offline   Reply With Quote
