dynoed again with sr16 cams - SR20 Forum
Old 04-16-2007, 02:01 PM   #1 (permalink)
the proof wizard
Feedback Score: 26 reviews
here is my new dyno sheet (corrected).
the graph shows the stock cams vs the sr16 cams
mods are
sr20ve
sr16 cams
calum ecu
safc II
ssac header
3in exhaust
msd switch set @ 4800
timming @~12degrees made the most power everywhere...
here is the previous dyno thred with stock sr20 cams
http://www.sr20forum.com/sr20ve-sr16ve/190993-just-got-off-dyno.html
12sec NA
Old 04-16-2007, 02:08 PM   #2 (permalink)
Feedback Score: 6 reviews
Not bad, that 13.5 @ 100 is pretty much on target. What 60ft did you get?
with 2.4 60ft vvls down in florida making 200whp usually run 13.9 , 13.8 at 100-101 mph.
502whp STOCK SR20DE BABY!!!!!!!!!
Soon to come 600+WHP SR20DE-T (Fully Built)
danilo20 is offline   Reply With Quote
Old 04-16-2007, 02:09 PM   #3 (permalink)
the proof wizard
http://www.sr20forum.com/drag-racing/195695-ve-goes-13-5%40100mph.html
Old 04-16-2007, 02:15 PM   #4 (permalink)
vz-r driver
really nice graph.....
THOR is offline   Reply With Quote
Old 04-16-2007, 04:58 PM   #5 (permalink)
SUNNYs are 4door?!?1!?!?1
Feedback Score: 9 reviews
Nice numbers! Damn every time I see a VE dyno sheet, I wish I had one. I need a better paying job. $8.75/hr is gonna take my half a year to get a VE.
Cheddar7171 is offline   Reply With Quote
Old 04-16-2007, 06:23 PM   #6 (permalink)
SR20DEEP N.Y.C.
Feedback Score: 46 reviews
@15 degrees....that the 1st i heard that 15 degrees on the calum ecu made more power.....i was under the impression that 10 degrees was best. very nice #'s bro
SR20DEEP N.Y.C.
LOCK IT UP!
DEAD SE-RIOUS is offline   Reply With Quote
Old 04-16-2007, 09:19 PM   #7 (permalink)
By it being a calum ecu doesnt mean it has same timing map as all the rest. His computer might have updated timing map. I know the one weve seen which was the base map of sr16, we had to go little bit lower then 10.
Old 04-16-2007, 09:39 PM   #8 (permalink)
myprojectB13's Avatar
Feedback Score: 17 reviews
Looks fun, how does it feel?
Jonathon
1996 G20
1993 SE-R 13.35@102
Old 04-17-2007, 12:15 AM   #9 (permalink)
That look like 10whp increasement by changing the cam only.
Quite impressive
Arrhh
cmng is offline   Reply With Quote
Old 04-17-2007, 09:01 AM   #10 (permalink)
I'm having a hard time reading the graph, but I thought it was typical for the SR6 low cams to make less power than the SR20 low cams before switch over, and the SR16 high cams to outperform the SR20 high cams at higher RPMs. But in this graph, I see the SR16 cams outperforming the SR20 cams at all RPM.
Am I missing something?
Old 04-17-2007, 11:31 AM   #11 (permalink)
the proof wizard
Quite impressive
yup, thanx for the cams
Old 04-17-2007, 11:33 AM   #12 (permalink)
the proof wizard
thats why i was letting you guys know............ we just played with the timming, kept raising it until we lost power, and ended up at 15..
Old 04-17-2007, 11:37 AM   #13 (permalink)
the proof wizard
idk what to tell you, the cams made more power everywhere... the only other thing we changed was the timming. the timming was set to 10degrees with stock cams and 15 with the sr16s
Old 04-17-2007, 12:05 PM   #14 (permalink)
ClamSlut
Calum's Avatar
Here's the stock SR16VE timing curve (and whats on the basic ECUs unless you specify something different):
RPM - Timing
3200 - 25
3600 - 30
4400 - 31
4800 - 31
5200 - 32
5600 - 32
6000 - 32
6800 - 32
7200 - 33
8000 - 34
This is the stock SR20VE:
3200 - 26
3600 - 28
4000 - 26
4400 - 28
4800 - 26
5200 - 27
5600 - 26
6000 - 29
6400 - 31
...and this is what we ended up with on a VE with 16VE cams, fuji header, and 60mm exhaust:
3200 - 21
3600 - 23
4000 - 24
4400 - 24
4800 - 25
5200 - 29
5600 - 30
6000 - 31
6400 - 33
7200 - 28
I forget where the above had the cam switching set to, that will make a difference. This is the kind of tuning that with a realtime ecu you can find not just peak power but more power under the curve at lower rpms.
Old 04-17-2007, 12:11 PM   #15 (permalink)
I really don't think that using the 1.6L for a 2.0L works too well. The 1.6 has a shorter stroke and spends less time at TDC, hence the need for more timing.
I haven't had a chance to dyno yet, but at the dragstrip last week, I pulled 4* of timing out of your supplied 1.6 timing map and the car was quicker and had the same MPH (97 MPH). When I got back from the track I adapted the OEM 2.0L VE map to 8000 RPMS and the car felt like it woke up. Again, this is only seat of the pants, I hope to have dyno graphs to back it up soon. My .02.
I love my Realtime ECU.
RPM - Timing
3200 - 25
3600 - 30
4400 - 31
4800 - 31
5200 - 32
5600 - 32
6000 - 32
6800 - 32
7200 - 33
8000 - 34
3200 - 26
3600 - 28
4000 - 26
4400 - 28
4800 - 26
5200 - 27
5600 - 26
6000 - 29
6400 - 31
3200 - 21
3600 - 23
4000 - 24
4400 - 24
4800 - 25
5200 - 29
5600 - 30
6000 - 31
6400 - 33
7200 - 28
Old 04-17-2007, 12:26 PM   #16 (permalink)
ClamSlut
Calum's Avatar
Your right. We need a much better standard VE program. I think just using the 20VE timing curve is a step in the right direction. Dyno tune yours and I'll switch to that, if your making your program public.
I'm happy with where the SR16VE cam program ended up. I think there's still plenty of room to grow, buts its a pretty decent base.
Here's something else to play with: for a car that is all/mostly a racecar, change the rpm scaling to 1000rpm,2000rpm,3000rpm,4000rpm, then very fine increments from there to just below your redline. You loose resolution down low, but you can really fine tune the power band. The car will still drive just fine with the big jumps down low, no problems there.
Old 04-17-2007, 12:34 PM   #17 (permalink)
I don't mind sharing at all, that was your hope with the new ECUs right? Makes sense about rescaling the RPMs, find your peak torque on a dyno then fine tune right there.
Old 04-17-2007, 12:41 PM   #18 (permalink)
ClamSlut
Calum's Avatar
Yea, but I understand people wanting to keep what they've spent money developing private.
Old 04-17-2007, 02:27 PM   #19 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
RPM - Timing
3200 - 25
3600 - 30
4400 - 31
4800 - 31
5200 - 32
5600 - 32
6000 - 32
6800 - 32
7200 - 33
8000 - 34
3200 - 26
3600 - 28
4000 - 26
4400 - 28
4800 - 26
5200 - 27
5600 - 26
6000 - 29
6400 - 31
3200 - 21
3600 - 23
4000 - 24
4400 - 24
4800 - 25
5200 - 29
5600 - 30
6000 - 31
6400 - 33
7200 - 28
5100 and 5500.
The community is here.
Old 12-12-2008, 03:39 PM   #20 (permalink)
VVL sucks in pedestrians
Feedback Score: 5 reviews
Sorry to bring this thread from the dead, but had a question for Calum:
Is the Basic VE program that you supplied this summer corresponds to the below sr16ve timing maps? I noticed that I get more power at 13* base timing on my VE instead of the 15* you have indicated. Let me know thanks.
RPM - Timing
3200 - 25
3600 - 30
4400 - 31
4800 - 31
5200 - 32
5600 - 32
6000 - 32
6800 - 32
7200 - 33
8000 - 34
3200 - 26
3600 - 28
4000 - 26
4400 - 28
4800 - 26
5200 - 27
5600 - 26
6000 - 29
6400 - 31
3200 - 21
3600 - 23
4000 - 24
4400 - 24
4800 - 25
5200 - 29
5600 - 30
6000 - 31
6400 - 33
7200 - 28
NX2000 - VE transplant in progress...
Wojtek1977 is offline   Reply With Quote
