Old 06-10-2002, 12:52 PM   #1 (permalink)
Are there different types of SR20VE's?
Hi Guys,
I'm interested in buying a SR20VE and am wondering if there are different types of VE's? like how there are different types of SR20DET's.
Or is there just 1?
Are there HP differences? Also when was the earliest they were introduced?
cool thanks
T.
Tephra is offline   Reply With Quote
Old 06-10-2002, 02:42 PM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
There are 5 VE motors.
SR16VE 175 HP 5 speed Manual 97-2001
SR16VE 200 HP 5 speed Manual 97-98 N1
SR20VE 190 HP CVT 6 speed Auto 97-2001 not so sure
SR20VE 204 HP 6 speed Manual 2001-
SR20VET 280 HP AWD Drive 2002-
Most of these figures and years are correct might be off somewhere did not look at my Nissan Maual when doing this.
Andreas Miko
Old 06-10-2002, 02:46 PM   #3 (permalink)
Andreas Miko
The second SR16VE that Andreas mentions is the SR16VE N1 version that is so hard to find because only 400 or so were made. Lets not dream about that one to much.
Steve
Steve
06 G35 6MT
Old 06-11-2002, 12:36 AM   #4 (permalink)
So for the actual SR20VE there are 2 types?
What does CVT stand for and is that tiptronic? And are there any identifing marks/numbers to tell the 2 engines appart, assuming the tranny has been disconnected?
I'm Looking to put on into the 92 Nissan Pulsar N14 SSS (Sunny) will both these engines bolt straight upto the existing transmission?
Cheers
Dave
Old 06-11-2002, 01:04 AM   #5 (permalink)
banned
Trader Rating: 5 (86%)
SR20V(E) SR20VE
The 204 hp SR20V(E) looks totally different than the 190 hp SR20VE.
SR20V(E) has a black valve cover with spark plug cover and it says in red writting (NEO VVL) and has an actual nissan emblem on the valve cover.
charlie2020 is offline   Reply With Quote
Old 06-11-2002, 01:18 AM   #6 (permalink)
Cool thanks
What about engine numbers, this engine is in another state and I cant see it so I was going to get them to email the engine #.
Old 06-11-2002, 02:29 AM   #7 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
Cheers
Dave
CVT is continuously variable transmission. Its an automatic that finds the best gear ratio depending on engine load and speed, to give the best gas milage as well as power and response. It can also go into a "triptronic" mode to allow the driver 6 set gear ratios to shift. Honda Civic HX from 96-20 has this transmission in it to produce 115hp and gets about 45-55 mpg
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-11-2002, 10:54 AM   #8 (permalink)
Would the all wheel drive SR20VET engine be compatible with the fwd 200sx with some modification.. and if so, what would it take?
brad67 is offline   Reply With Quote
Old 06-11-2002, 07:29 PM   #9 (permalink)
No one knows because it hasn't been done. I would imagine the engine bolts right up to our transmission though. Good luck finding one.
Lyn Labahn is offline   Reply With Quote
Old 06-12-2002, 12:27 AM   #10 (permalink)
It's sort of a dream/fantasy.. but it would only happen after I graduate, get a job, and pay back my student loans..sooooooo hopefully someone will find out before me.. and by then maybe there will be an even better engine to put in.. who know
Old 06-17-2002, 01:55 AM   #11 (permalink)
I dont know where else to put this and i dont want to start a new thread just for this info.......but just incase anybody was wondering if the sr20ve where also made for the Nissan Wingroad.
http://www.nissan-
global.com/GCC/Japan/NEWS/19990531_0e.html
check it out.
Mindset is offline   Reply With Quote
Old 06-17-2002, 09:43 AM   #12 (permalink)
爆走
yes the sr20vve is in the wingroad as i remember
Old 07-13-2002, 02:33 PM   #13 (permalink)
HELP!! B12 SR20VE SWAP...
HI there!!!
i have a b12 4 door sentra andplanning to swap a sr20de, but learning about the sr20ve changed my plans for my car. so i have a lot questions since i'm unfamiliar on how to drop a sr20ve in a b12.
your expert answers will help me a lot in my project...
my friend is an importer of surplus parts from japan and i told him to find me a nissan primera that have the sr20ve.
my questions are...
do you think i could get a front clip of a nissan primera??
do you think i could get a sr20ve 6 speed manual???
can i swap the sr20de 5 speed tranny???will it bolt right in???
if i got the sr20ve tiptronic automatic, can i use its ecu??? or it is different from the manual ecu???
is the sr20de and the sr20ve have the same bracket designs for the engine support???
how complicated would it be to drop a sr20ve in a b12??
does the sr20de driveshafts fit into the b12 disc brakes?? or do they need modification???
does anyone have a wiring diagram for the sr20ve??? if you have one and ur kind enough, pls notify me or email it to me..
does the sr20ve and sr20de have the same maintenance parts like the oil filter, fuel filter, gaskets, distributor etc...???
i need your help guys!!!
thanks...
b12sr20ve is offline   Reply With Quote
Old 07-13-2002, 05:32 PM   #14 (permalink)
爆走
my questions are...
do you think i could get a front clip of a nissan primera?? yes, but why do you need the whole clip. a paulsar vzr clip would be better
do you think i could get a sr20ve 6 speed manual??? yess but its expensive
can i swap the sr20de 5 speed tranny???will it bolt right in??? to the engine yes, but you have to fab your b12
if i got the sr20ve tiptronic automatic, can i use its ecu??? or it is different from the manual ecu??? you can use it, it didnt come in a manual version. you will have a MIL(check light) all the time i think.
is the sr20de and the sr20ve have the same bracket designs for the engine support??? yes
how complicated would it be to drop a sr20ve in a b12?? you have to weld in new mounts to the frame, use se-r axles, use sr20 tranny, lower the car 2 inches so the axles dont bind.
does the sr20de driveshafts fit into the b12 disc brakes?? or do they need modification??? they fit
does anyone have a wiring diagram for the sr20ve??? if you have one and ur kind enough, pls notify me or email it to me.. i have them if you do this swap i can help you out then
does the sr20ve and sr20de have the same maintenance parts like the oil filter, fuel filter, gaskets, distributor etc...??? uses 95+ oil filter, most all gaskets are different, has different distributor.
Old 07-15-2002, 05:36 AM   #15 (permalink)
re: help! b12 sr20ve swap
COZ *** U G THE FRONT CUT OF THE CAR, TH HARNESSES R UNCUT, SO THEY THE REWIRING IS NOT SO DIFICULT... A PULSAR VZR CLIP?? WHY IS IT BETTER?
ITS EXPENSIV COZ ITS NEW?? HOW MUCH DO I GET THE SR20VE AUTOMATIC?? HOW MUCH DO I GET D VZR CLIP
WHA DO U MEAN? FABRICATE THE SUPORT FOR THE TRANY?
IS'NT IT THE MNUAL ECU TUNED BETTER 4 MANUAL THAN THE TIPTRONIC? OR THEYR D SAME?
MY CAR IS ALREADY LOWERED, AND IT WILL BE COZ THE SR20 IS HEAVY..HEHEHE. MY FRIEND, HES A MECHANIC AND HE DOES ALL D SWAPS AND TUNING ON OUR CARS. HE SAID THAT INSTEAD OF MOVING THE ENGINE SUPORTS, ITS BETTER TO FABRICATE NEW BRACKETS 4 THE ENGINE TO FIT THE ENGINE SUPORTS. HE SAID MOVING THE FACTORY SUPORTS IS IMPROPER. DO YOU AGREE??
YES I WILL DEFINITELY DO THE SWAP, SO AS THERE **** B MORE FAST NISSANS ON THE STRIP N STREET...(TYPE R'S BETTER WTCH OUT!) BUT THAT ALSO DEPENDS ON MY FRIEND IF HE CAN GET ME ONE.
ABOUT THE WIRING DIAGRAM I WILL NOTIFY YOU WHEN I NED IT IN THE FUTURE...
HOW DO U THINK HOW CAN I GET THOSE PARTS FROM HRE IN PHILIPPINES? FROM JAPAN ALSO?? WE DONT HAVE SE-R'S HERE... WE ONLY HAVE THE ALTIMA THAT HAS THE HIGH PORT SR20DE...
WHAT CAR DO U HAVE? DO HAVE THE VE? IF YES WHATS ITS 1/4 MILE TIME???
HEY TOM THANKS FOR THE INFO!!! U WILL BE A REALLY BIG HELP...OUR FRIEND MECHANIC WILL BE HAPPY TO FIND OUT THAT DROPING THE SR IS NOT THAT COMPLICATED AND THE AXLES FIT THE B12 BRAKES. TNX!!!
Old 07-15-2002, 07:11 AM   #16 (permalink)
爆走
it is silly to try to use the japanese harnes in a us car. rewiring your current harness is easier.
Old 07-18-2002, 07:51 AM   #17 (permalink)
yes i agree wd you but wiring guys here in the philippines prefer uncut harnesses beacuse they are easy to trace and rewire if u dont hav the wiring diagram.. on my side, beacuse its easier,the labor is much more cheaper like 30%...: )
why is the pulsar vzr clip better?? does it have the sr20 or the sr16??
unfortunately we dont have SE-Rs here in the philippines.
what tranny should i get from japan??? the primera sr20de tranny??? is it cable type??
what axles should i get??? the primera sr20de axles??? do they fit in the b12 disc brakes???
thanks...
Old 07-18-2002, 07:51 AM   #18 (permalink)
re help b12 sr20ve swap
BIGTOM
thanks...
Old 07-18-2002, 08:59 AM   #19 (permalink)
bigtom has a racebuilt sentra E, with the sr20ve he runs a 12.8 in the 1/4 mile...
(sorry tom had to beat ya to the punch, -the rumormonger-)
.xsanity.
2k1 SE, PP. Blackout, looks meaner, breathes better, sits lower, and grabs the ground a little tighter.
.san diego. http://members.cox.net/exitsanity
Xsanity is offline   Reply With Quote
Old 07-19-2002, 09:41 AM   #20 (permalink)
Xsanity
wow! a sentra E? is that a b12 or a b13?? what mods does the VE have?? or its stock??? im really gonna pusue in getting a VE for my b12....
