Old 05-20-2007, 03:31 PM   #1 (permalink)
done
VE header/cam dyno
nevermind
Old 05-20-2007, 03:35 PM   #2 (permalink)
NA>Boost
nice job/numbers...glad to see some of the hard work paying off. Do those custom grind's require S/R?
SR20DEEP CT
sr20gti-r is offline   Reply With Quote
Old 05-20-2007, 03:37 PM   #3 (permalink)
Enemy of the stupid
Nice work chuck. Those SAE #'s? The power that 4-1 made over the Fuji is great not just on the top but all over the place.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 05-20-2007, 03:49 PM   #4 (permalink)
I have some question
Do that Engine Retain stock Spring and Retainer ?
Do the Rev show is 7500 rpm? it not so clear there
if YES
WOW>.
what a impressive result for bolt on cam only
i really wonder what it can do N1 intake manifold and proper tuning
and Rev it to 9000 rpm if the Spring and retainer is changed as well
Arrhh
cmng is offline   Reply With Quote
Old 05-20-2007, 04:07 PM   #5 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Here is my opinion
graph 1
base run with Fuji header 196 HP
second run with 4 into 1 non stepped header 200 HP
Graph 2
second run with stepped 4 into 1 header 203 HP
Graph 3
base run with Fuji header196 HP
second run with N1 cams, cam gears +4 and -4 with 4 into 1 stepped header.and 209 HP
Looks like the straight 4 into 1 makes way more mid range torque and the stepped 4 into 1 makes more topend HP
These I feel are the correct figures. I feel that the spike at the end of the graph is from letting off of the dyno as this is generally a trend you see on most dynos and can be seen at the end of every pass on each graph. The torque and HP will not fall off and go up like that at the end of a power graph. This can be seen more so on graph 1 where the power up top is falling off and then spikes up exaple on the torque section.
Great comparision and thanks for the hard work Charles.
Old 05-20-2007, 04:17 PM   #6 (permalink)
Just LTrain Again..
Very interesting. Thanks for posting!
VVL
'94 SE-R w/ VE ....sale pending
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 05-20-2007, 05:06 PM   #7 (permalink)
P10 pro
I agree with Andreas #, you have to ignore the spike at the end. These are very good #s nonetheless.
I think the motor would have made more with the rev limiter removed.
Charles, were the headers dynoed open or connected to the exhaust?
5speed is offline   Reply With Quote
Old 05-20-2007, 05:26 PM   #8 (permalink)
i love b13's !
Trader Rating: 22 (100%)
thats bad fu*king ass bro.
all basically stock motors with nothing but cams and headers.
makes u think what big big cams, head work, bottom end work with highcompression and those headers will put down !
great work.
stratton.
im back.......
Old 05-20-2007, 05:33 PM   #9 (permalink)
merely a flesh wound
chriscar's Avatar
How are you able to run the 333 injectors on a G20 ecu and not run rich as a bitch?
Old 05-20-2007, 05:39 PM   #10 (permalink)
Jah Rastafari
great work.
stratton.
A 2.2 L VE with 12 to 1 compression, (SR20turbofreak) header, Ported Head and cams in the 12.5mm lift with 304 degrees duration would make an easy 240-250 WHP motor.
So as you guys can see there is real potential here.
Also you guys will find that SR20turbo freaks header will perform better on a larger 2.2-2.4 L motor. Why you ask because the larger motor will give the big torque numbers in the mid range and the header will take care of the top end power.
So from reading these facts
The 4 into 1 header with 1.75 runners at 30 in primaries with 2.38 collector that is modeled after the header on my car which Greg V will be selling will be best for a 2 L motor with all the bolt ons.
The 4 into 1 SR20turbofreak stepped header at 26 inches will be better for high compression and or larger motors wil ported heads high compression and so on.
You guys know I will be rocking the Freakmasters stepped header on my 2.3L motor.
Old 05-20-2007, 05:39 PM   #11 (permalink)
The Boost Bear..Rawr!
Zexel's Avatar
Trader Rating: 42 (98%)
Great runs! Charles is doing great things for you crazed VE guys.
Zexel is offline   Reply With Quote
Old 05-20-2007, 06:17 PM   #12 (permalink)
i love b13's !
this is what we needed. this can make the all motor nissans extremely competative.
what other n/a 4 cyclinder is gonna rock with the 215whp 156ft motor. thats right in k territory, with a light enough hatch its killing them big time.
makes me want ve. i think i know what my next project is.
stratton.
Old 05-20-2007, 06:27 PM   #13 (permalink)
98 SE
Great work Chuck and thanks for putting in the hours
Koni www.koni-na.com
www.nissanroadracing.com
Old 05-20-2007, 07:18 PM   #14 (permalink)
SUNNYs are 4door?!?1!?!?1
Wow very nice work. Good info for the VE guys. This is R&D at its best.
Cheddar7171 is offline   Reply With Quote
Old 05-20-2007, 07:58 PM   #15 (permalink)
huh?
Ric
VePwrd 97 Se-r (jwt free)
VqPwrd 07 Fronty
Teal97 is offline   Reply With Quote
Old 05-20-2007, 08:24 PM   #16 (permalink)
Very damn impressive.
-Rob-
Get ready for a big SE-Rprise
Old 05-20-2007, 08:38 PM   #17 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
I'm gonna bump this question as it looks like the redline is 7500 RPMS.
The N1 cams peak HP numbers should be at 8200RPMS if I'm not mistaken. So, the WHP number should go up quite a bit with a NO redine ECU.
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 05-20-2007, 08:46 PM   #18 (permalink)
done
nevermind
Old 05-20-2007, 09:04 PM   #19 (permalink)
XxToKeSxX's Avatar
Very nice...
I think patiently waiting for you VE boys to do your thing has proven wise. Crazy power/dollar compared to the honda boys. This is very exciting. Give it a year or two and I'll be rockin' one... Until then I will continue to wait and watch the results.
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 05-20-2007, 09:11 PM   #20 (permalink)
chriscar's Avatar
Originally Posted by Teal97 View Post
nismo afpr set @ 34psi w/o vacuum
I'm lost. You're running a little over 2 bar fuel pressure to compensate for the larger injectors? That's some innovative sh*t right there.
