Old 05-21-2007, 03:26 AM   #1 (permalink)
Help !! Confusion on VE Engine compression
I do search around
but still could not get the comfirmation of the actual engine compression when i put the following piston on VE block
Block = SR16VE
Rod = SR20VE
Crank =SR20VE
Gasket = Nissan OEM 20V metal gasket
what compression i will get if i use the following piston :
SR16VE piston
SR20VE piston
SR20VE 20V piston
SR20DE piston
Z32 NA 87mm Piston
Or any piston that will make the engine compression in between 11 to 12 ?
Thank you very much
Arrhh
cmng is offline   Reply With Quote
Old 05-21-2007, 07:34 PM   #2 (permalink)
SE-R Geek / Nissan Tech
which head; whats the compressed thickness of that gasket; what are the complete specs of each of those pistons (i.e. compression height, pin height, etc)?
92 SE-R Autocrosser.... too much to list
Old 05-21-2007, 09:47 PM   #3 (permalink)
sr16ve Block = sr20ve block
sr20ve rods = sr20de rods
sr20ve crank = sr20de crank
sr16ve head = sr20ve head (cams are only difference)
Ziyad is offline   Reply With Quote
Old 05-21-2007, 09:58 PM   #4 (permalink)
Assuming ve block and head....
sr20ve piston = 10.3
sr20de piston = 10.3
sr20ve 20v piston = 11
Old 05-21-2007, 10:12 PM   #5 (permalink)
sr16ve piston = 13.5
Old 05-21-2007, 10:26 PM   #6 (permalink)
Thank
So i can assume as following
Block = SR16VE
Rod = SR20VE
Crank =SR20VE
SR16VE piston = 13.5
SR20VE piston = 10.3
SR20VE 20V piston = 11.0
SR20DE piston = 10.3
Z32 NA 87mm Piston
DE and VE piston is same ?
Thank you
Old 05-21-2007, 10:49 PM   #7 (permalink)
DE and VE pistons are different.
VE piston has notches for the valves.
Check this link for sr16, de, and de uk pistons
You can see the valve notches in the sr16 piston.
