This motor is on par with the SR20VE, it comes with a Titanium header. I wonder what front wheel drive Toyota you could stick this into. Maybe one of those first FWD Corolas. or one of the new gen corrolas with the nice body kits
We had a MR2 with a worked one of those on the dyno the same day that EVLNXR and I were there, it was the second most powerful NA engine of the day at 129wkw.
3SGE motor is from the mid 80's to late 90's Celica but also used in the SW20 MR2.
The 3SGTE was in the GT4 Celica rally car and also the MR2 turbo's.
The 4AGE 1.6L 20 valve Toyota's had a series 1 and 2, both using quad throttle bodies. The blacktop 20 valve motor made 123Kw and the silver top made 119Kw. There was also the 4AGZE screw supercharger 1.6L motor. Popluar to fit these 4A engines to early model MR2's and Haichi Roku's(AE86's)
Would not mind seeing the RS200 3SGE Beams motor in a Hachi Roku...
A guy in Orlando that we used to hang out with stuffed a 3S-GTE into his hachiroku, does that count?
hahahaha
He used the Altezza 3S bellhousing and tranny I think, but made custom mounts and such for the motor. Had a decent sized snail on there. Think he put down like 350hp or something to the wheels, on a gutted AE86 w/ roll cage and full suspension and CCW wheels. Car was hot.
also, not to knock you miko, but after looking at the title of this thread i should also say that its diff then vtec, it has adjustable timming on both the intake and exhaust, but not lift. simmilar to vtc but on both the intake and exhaust sides....
you are correct. there is no VVL or VTEC like action. its a VVT-i motor which is just "intelligent variable valve timing" VVTL-i is the one like vtec.
I think only the 2ZZ got the VVTL-i action. One of my friends had a 01 Celica GTS that had all sorts of TRD goodies in it, and we were driving around in his car and he kept hitting "VTEC" so to speak, it was a blast.
