Old 05-26-2007, 10:05 AM   #1 (permalink)
Hard starting
Hi guys
I've recently done a VE swap on my p11 and i've noticed that after the cars sat for a while when i start it the starter goes for about 10 seconds before the engine splutters to life. After its started it goes sweet. Does anyone know how to correct this?
nocabiwiksmx is offline   Reply With Quote
Old 05-26-2007, 10:27 AM   #2 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
My car recently started to do this. Even though its not a VE I think its possible that your injector O-rings could be leaking. Wouldn't hurt to give that a shot.
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 05-26-2007, 11:11 AM   #3 (permalink)
AKA-- JJKAMIKAZE
my ve does this too. are you using a de ecu, or a calum, or jw? anouther thing i noticed is that it seems like my de starter has trouble kicking over the higher compression VE and the starter makes a loud whining noice.
NismoTheDog is offline   Reply With Quote
Old 05-26-2007, 06:27 PM   #4 (permalink)
im using a daughterboarded sr20ve ecu
it also had this problem with an sr16ve ecu
im runnin 370cc injectors so one may not be seated properly ill take the fuel rail off anc check today
Old 05-30-2007, 07:07 AM   #5 (permalink)
seen the light
Did you get this issue sorted, Aaron?
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 05-30-2007, 04:55 PM   #6 (permalink)
kieran and i tried changing the injector seals the other night amking sure we greased them up good but the problem still exists
next thing to try is an sr20ve starter motor apparently they are different
