Old 05-28-2007, 02:15 AM   #1 (permalink)
Stroker Kit Advice
Whats up fellas.I'm thinking of buying a stroker kit from Rage Performance in Florida.This kit is for a DE.So what compression piston should I get so the ve engine will be at 11.1 compression or whats the highest compession piston I can use on 93 octane.I'm going to use N1 cams so how deep should I get the valve notches.I dont have enough money for sleeves so whats the max bore with stock sleeves.I'm also going to spray a 100 shot.I need all this information before buying.All advice will be aprecciated.
sr20venosfreak is offline   Reply With Quote
Old 05-28-2007, 05:28 AM   #2 (permalink)
src
The max bore you can use is 87.5mm. It is tested on my DE: 40,000km with hard pulls on the track and street, 8500+ rpm without problems on piston/sleeves side.
The valve notches would be like 16VE ones.
src is offline   Reply With Quote
Old 05-28-2007, 12:57 PM   #3 (permalink)
Out of business
Trader Rating: 44 (100%)
Just get the BC kit from SR20turbofreak, he'll hook you up, with a good deal
In Loving Memory of ZAD,We LUV Ya ta Death, Save us a Spot Next To Ya Up There, we'll see you soon
He can make 200,250 or even 300whp! Because at the end of the day, He's not going no where but up and down Liberty Avenue stuntin for the rest of his fellow Indian friends!
If ya want JDM go the fu_k to Japan
4Doors and not 2 are the real Sunny's
RE-Spect is offline   Reply With Quote
Old 05-28-2007, 02:29 PM   #4 (permalink)
BC???
PR20DE is offline   Reply With Quote
Old 05-28-2007, 03:10 PM   #5 (permalink)
Out of business
Originally Posted by PR20DE View Post
BC???
Brian Crower
Old 05-28-2007, 03:10 PM   #6 (permalink)
Does any body know the price and spec's.
Old 05-28-2007, 03:12 PM   #7 (permalink)
Se-riously???
http://www.crower.com/
I've always wanted a RWD SE-R, maybe after I win the Lotto.
Nismoguy is offline   Reply With Quote
Old 05-28-2007, 03:13 PM   #8 (permalink)
Originally Posted by Nismoguy View Post
Thanks
Old 05-28-2007, 03:21 PM   #9 (permalink)
It don't specify whats the spec's
Old 05-28-2007, 03:56 PM   #10 (permalink)
We sell the BC stroker kit where i work and have never had a problem with the kit.
SBR240sx is offline   Reply With Quote
Old 05-28-2007, 04:14 PM   #11 (permalink)
How much does it cost.
Old 05-28-2007, 06:44 PM   #12 (permalink)
done
nevermind
