Old 05-30-2007, 12:27 PM   #1 (permalink)
Trader Rating: 16 (100%)
Low cam, High rev: Teh DANGER?
Just wondering what would happen if my cam switchover electronics fritzed out at 8K RPM and cut out the high cam. Would running on the low cam at that speed be disasterous?
_SHig
SHigSpeed is offline   Reply With Quote
Old 05-30-2007, 12:35 PM   #2 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
I think you would be fine... there have been others that ran on the low cams for whatever reason.
Old 05-30-2007, 12:36 PM   #3 (permalink)
At max RPM even? I know the lift is lower, but would the valves float or could the lifters get flung due to the ramp angles?
_SHig
Old 05-30-2007, 12:40 PM   #4 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
The Greddy MSS is notorious for doing this if you take the rpm signal from the distro. I never heard of anyone messing up their rig from it though.
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
Old 05-30-2007, 12:41 PM   #5 (permalink)
the proof wizard
Trader Rating: 26 (100%)
i wouldnt worry, your fine, you have to remember the low cams are always spinning, its not like they stop moving after the high cams come on...
12sec NA
Old 05-30-2007, 12:45 PM   #6 (permalink)
McCoy's Avatar
I've seen people dyno with just the low cams engaged and with the high cams only just to see the crossover points... so I would have assumed they ran the car near redline with just the low cams.
Did the cams switch from high to low at 8K rpm, or just not engage when it should have?!?
Old 05-30-2007, 12:47 PM   #7 (permalink)
eric96ser's Avatar
Running on the low cams, is just like running a DE on stock cams.
1991 Sentra SE-R
The community is here.
Old 05-30-2007, 12:59 PM   #8 (permalink)
No experience yet, but I'm just trying to see how bulletproof the switching system needs to be.
I'd think that it's not quite like running on DE stock cams, which would not be happy at 8K I'd think. The VE small cams must be smaller than DE cams, right?
I'd hate to be zipping along at max revs and then have the high cams drop out and fire the valves through the pistons as a result! :^)
_SHig
Old 05-30-2007, 01:39 PM   #9 (permalink)
the proof wizard
_SHig
actually the low cams and stock de cams are pretty close.... but dont worry so much
Old 05-30-2007, 01:47 PM   #10 (permalink)
Heh! I'll start worrying after "the incident" then... <LOL>
Thanks for all the input.
_SHig
Old 05-30-2007, 02:22 PM   #11 (permalink)
SR20VE powered P11 GT
Standard SR20VE low cams and DE cams are all but the same. I regually reved my DE round to 7000rpm, and I've had her bouncing the rev limiter in all gear but 5th... You will have absolutly no problems giving the VE low cams the same abuse. The only differnce will be you'll be pushing out only 150ish bhp instad of 180ish...
Old 05-30-2007, 05:04 PM   #12 (permalink)
My ECU fault caused the solenoids to 'flutter' (rapidly switch on & off) one night at about 8,000rpm. Gave me a hell of a fright but as far as I can tell, didn't damage anything.
Clint is offline   Reply With Quote
Old 05-30-2007, 05:22 PM   #13 (permalink)
Holy $HIT! That'd make me soil my shorts!
Okay, I DEFINITELY never want to experience that...
_SHig
Old 05-31-2007, 11:46 PM   #14 (permalink)
AKA-- JJKAMIKAZE
kinda related, is is bad to ride at the switch point rpm, where the solenoid kinda flicks on and off.
NismoTheDog is offline   Reply With Quote
Old 06-01-2007, 12:51 PM   #15 (permalink)
Hater of 240sx ASSHATS #2
You should probably try to avoid that.
If you must cruise at that RPM, at least temporarily change the switch over point to a higher value so you don't mess anything up.
SoSideways is offline   Reply With Quote
Old 06-04-2007, 08:24 PM   #16 (permalink)
BTCC VE Power
thats why its good to have a mss, you can control wether or not it switches using the tps as well... good for "passing on the highway" get in gear, cruis at the proper rpm, say 4500 then when you floor it, it will instantly switch, instead of on/off on /off
KL0 P11 Sport
Surround Sound
My VE thread
