In an idle moment this evening after work, I decided to strip off the cam switches and double check they were working. Thought I'd share the pics with you...
Housing is to the left, with the intake, the exhaust cam switch to the right. Below them is the little oil filter that can become blocked and be the cause of loss of high cam...
The oil feed is the banjo shaped open in the center. To the right is the low cam return and to the right are the high cam returns....
