Old 06-01-2007, 12:12 PM   #1 (permalink)
sr20ve + sr16 exhaust cam = ?
Here's the situation... Im getting an sr16 exhaust cam only, at a reasonable price.
What difference will I get in my stock sr20ve?
Ziyad is offline   Reply With Quote
Old 06-01-2007, 12:37 PM   #2 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
hey i think its worth it, you will gain a few ponies as doing both usualy gets you around 10 hp, the exhaust i think is the one that gains the most
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-01-2007, 01:17 PM   #3 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
The car will make less HP. Than with the stockSR20VE cams
These 2 cams are not matched together.
The cam timing is way off and will not work right but if you dont belive me give it a twirl.
Old 06-01-2007, 01:37 PM   #4 (permalink)
BTCC VE Power
well i guess theres your answer
Old 06-01-2007, 01:41 PM   #5 (permalink)
Exhaust cam only ?
I have the 16VE Intake cam only
possible you interested for it ?
Arrhh
cmng is offline   Reply With Quote
Old 06-01-2007, 06:33 PM   #6 (permalink)
G20 newb, not se-r geez!
We tried it already and it made zero gains, nada. It seems the power is on the intake side. We went back and forth with cam gears and ignition timing no gains.
JGG8891 is offline   Reply With Quote
Old 06-01-2007, 06:51 PM   #7 (permalink)
Thanks for the responses guys. Im now officially disappointed...
Old 06-01-2007, 06:53 PM   #8 (permalink)
Im a bit far from Malaysia... shipping will be a killer.
Old 06-01-2007, 10:11 PM   #9 (permalink)
since it only a single unit cam
somemore i selling it cheap
but i checked shipping to trinidad is double from shipping to US
crazy
Old 06-03-2007, 06:03 AM   #10 (permalink)
Very Very Loud too!
Say that i have my bone stock SR20VE and i opt for some more hp....So i'm buying a pair of SR16 cams and bolt them on. Would this gain of 10hp arise without any further tuning? .......Such as the use of an SR16 ECU? What would be better for this setup (SR20 with SR16 cams)? The stock 20VE ecu or an SR16 ecu?
Nikiforos-P10 is offline   Reply With Quote
Old 06-04-2007, 03:53 PM   #11 (permalink)
Very Very Loud too!
This may be a bit old but what do you reckon ?
The SR16VE cams can be swapped into the SR20VE motor for a gain of about 5-10 whp but slightly less torque- more a top end gain.........For slightly more power get both exhaust cams from the SR16VE, since they are larger than the intake cam, and reverse the dowel hole and pin on one of them to run it on the intake side. However, the SR20 has an asymmetrical cam lobe shape- the opening ramp is much steeper than the closing ramp. If you put the exhaust cam on the intake side the profile will be backwards, changing the cam lobe point of contact, the valve velocity, and decreasing duration. It will eventually affect valvetrain stability and long term durability at high rpm.
Source: Nissan Performance Mag
I apologize in case this one already exists. I have probably missed it.
