Old 06-03-2007, 05:12 AM   #1 (permalink)
VE power!
How can I run good quarter mile times?
Last Friday at firebird I ran 14.9 @ 93 mph and I was kinda bummed out about that since I read in the FAQ, it says that a VE in a se-r should run 13.8 14.2 with full interior. I ran full interior but no spare or jack. I would like to know how I can run better times.
Mods: DE HKS header w/ 2" outlet, OBX test pipe/resonator,
stock catback,
HKS muffler,
WAI w/apexi filter, 9lbs flywheel, jgy pressure plate w/oem disk (I dont like jgy) , Calum ECU w/VE "basic tune",
14* timing,
BFG drag radial T/A's @ 25+psi due to a malfuntioning tire gauge.
Next time I want to run straight header and take out the rear seat and 13psi in the tires. Any other recomendations?
E's 92' sr20 is offline   Reply With Quote
Old 06-03-2007, 05:14 AM   #2 (permalink)
VE power!
BTW it's a b13 and I ran 210 compression when tested today.
Old 06-03-2007, 05:20 AM   #3 (permalink)
Trader Rating: 0 (50%)
post your slip up
luckybull is offline   Reply With Quote
Old 06-03-2007, 05:28 AM   #4 (permalink)
VE power!
RT: .574
60' 2.320
330: 6.397
1/8: 9.712
1/8 mph: 75.25
1000' 12.550
1/4: 14.964
mph: 93.12
Old 06-03-2007, 05:43 AM   #5 (permalink)
The Genesis
^work on your 60ft time.
Old 06-03-2007, 05:50 AM   #6 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
Why is your timing so low???
Since your BFGs had so much PSI in them this definetly killed it for you. A 2.3 60' with BFGs is not good at all. Your trap speed should be higher also.
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 06-03-2007, 04:52 PM   #7 (permalink)
VE power!
You think I can bump my ign timing even more? How much timing should I run? I hear light weight flywheels are'nt good for launching. What rpm should I launch at?
I was using my friends "good" tire gauge at the track and it read 20psi, and that was as low as it would read out. When I got home I checked them with my gauge and it read 25psi. I was'nt to happy, but now they're at 13psi and ready for next friday.
Old 06-03-2007, 04:53 PM   #8 (permalink)
Broke Ass
jer_760's Avatar
Just as a reference, I ran 9.2 at 76mph with a 2.4 60' the last time I was at the track. Unfortunatly there arent any 1/4 mile tracks close to me.
SSAC 2.5" header
Place racing CAI
VRS 2.5" Exhaust
Two piece UR pullies
Calum ecu for 333inj, de maf
95 200sx
sr20ve
Old 06-03-2007, 04:55 PM   #9 (permalink)
Broke Ass
jer_760's Avatar
You will benifit from a lightweight flywheel, trust me. I still havent been able to tell what base timing feels the best with me calum ecu, I will have to wait for dyno time. I currently have it set at 15* IIRC
Edit: You should be able to launch around 6k with the bfg's
Old 06-03-2007, 05:49 PM   #10 (permalink)
SR20 POWA
well i ran 14.8 @ 93 last month..
heres my numbers
R/T: .466
60': 2.308
330': 6.347
1/8: 9.630
MPH: 74.68
1000: 12.448
1/4: 14.839
MPH: 93.66
i was using a DE ECU at the time w/VE INJ, DE MAF, SR16 Cams, Timing @ 20, street tires, SSAC header, 2.25 catback, WAI..
now it has a calum ecu and it runs way stronger..no more running rich..if i can find a video ill post it up..i was running open header/downpipe
92 Sentra Se-R (VE powered)
duntmesswitda_s is offline   Reply With Quote
Old 06-03-2007, 06:22 PM   #11 (permalink)
SR20 POWA
heres that video..
Old 06-03-2007, 06:45 PM   #12 (permalink)
1st thing we need to know the race weight, if your car is 2500lbs without driver, that trap shows about 160whp or so. Next thing is which gear are you finishing in, you should be crossing the line in 3rd. If not get a bigger tire size so you can stay in 3rd otherwise your trap will be lower. Also where did you run at, we need to know the DA (density Altitude) of that day which you can find weather and DA'. This tells you how much power the engine is making compared to a day were conditions would net you 100% engine output weather. For best results run on some 22in slicks that should net you 1.8-1.9x 60' which should put you in the low 14s.
stock catback,
HKS muffler,
14* timing,
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 06-03-2007, 07:02 PM   #13 (permalink)
Use to be ^
Did you port match your header? That header and exhaust is really hurting you. Let the engine breathe a little bit more and you'll improve your time dramatically.
*1991 SE-R TURBO SOLD!!!
*1990 240sx coupe SOLD!!!
*1991 SE-R SOLD!!!
*1996 Toyota Tacoma X-cab 2wd
*1991 Infiniti G20
*1989 240sx coupe
sentraturbo is offline   Reply With Quote
Old 06-03-2007, 08:49 PM   #14 (permalink)
Enemy of the stupid
Originally Posted by duntmesswitda_s View Post
heres that video..
Whats your rev limit at? I notice you hit 4th at the end of your run? or was that the other car I heard?
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 06-03-2007, 09:26 PM   #15 (permalink)
SR20 POWA
7500...that kinda hurted my time too..
Old 06-03-2007, 10:36 PM   #16 (permalink)
VE power!
Yes the header is port matched. I am shifting into 4th before the end of the 1/4mile. The track is Firebird Raceway in pheonix, AZ. I raced there on June 1st.
EDIT: I had realy bad wheel hop on that run and the next run I broke the rear motor mount bolts because of it.
Old 06-03-2007, 11:07 PM   #17 (permalink)
Professor Dingbat
The stock catback is killing you. A good 2.5" exhaust will be worth a couple of tenths.
Old 06-03-2007, 11:31 PM   #18 (permalink)
RIP Bob
Just get a DET and call it a day!
Martin Jez-EEN co-founder/vice president
2003 Kenworth W900L, C-15 CATERPILLAR with goodies
1021hp and 3470 lb-ft
Sneakers O'Toole is offline   Reply With Quote
Old 06-03-2007, 11:40 PM   #19 (permalink)
PWND by SR20's
Thats the spirit! Give up on N/A
"pause... NAAAT!!"
I think sentraturbo was right about the exhaust. you will notice a nice difference with some new piping. 3" maybe...
Video was still sick
Jeremy
_LOVIN VT_
VT Tech College Graduate w/ an Associates Degree in Automotive Technology
5 ASE Certifications
Full time Technician at South Burlington NISSAN
My First 2 cars__SE-R's
1st carAge 14_ Black-93 Sentra SE-R (Sold)
2nd carAge 15-present_ Black-95 200sx SE-R now with GTi-R
Retro Cruiser
White-87' Honda Accord LX-I Hatchback
haasyboy25 is offline   Reply With Quote
Old 06-04-2007, 03:32 AM   #20 (permalink)
VE power!
So I guess the only things I will be able to change asap is straight header, tire pressure (13psi), and mess around with the timing. I will also toss the rear seat.
The run where I broke the rear motor mount bolts was launched at 4500 rpm's, and the 14.9 run was launched at 4000 rpm's.
