I'll be hooking up the SR16 ecu shortly which has a higher red line then the 7000rpm on my stock dash display. Does anyone know of a company I can go to to get another set of dial faces with a higher red line...?
I am under the impression that there was a version of the P11 called sport, Si or somethin' like that...And i think that it was equipped with white gauges (tach n' speedo). Maybe you should go for it...
