Old 06-09-2007, 03:31 AM   #1 (permalink)
the proof wizard
Trader Rating: 26 (100%)
confused... extremely rich
well the other night i was driving everything was great, car was running awesome like always and i pulled into a parking lot and shut it off......
then like an hour later when i go to start it, it wont stay running, its running super rich, fuel comming out the exhuast...
so then today after work i went back there w my multi meter and checked the maf voltage, which read .03-.6v it would be one of the two, then the other next time i checked it again. this was with key on engine off. (n60 maf by the way, with a calum ecu.) i was under the impression that if it were close to but under 1v it was correct. the car still doesnt run w the maf unpluged.
when i wasnt sure that was the issue, i pulled the fuel rail and turned key on to see if the injectors were leaking, and nope. not at all. so for some reason there getting some crazy signal, if not the maf it must be the ecu.
now i have also tested another b13 ecu and its not any better....any suggestions?
12sec NA
Old 06-09-2007, 10:24 AM   #2 (permalink)
CAR SLÜT
Check the consult coolant temp sensor output temperature. Sounds like it is stuck in 'cold start' enrichment mode.
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 06-09-2007, 10:39 AM   #3 (permalink)
the proof wizard
it wont hardly run, it runs for like a few seconds... cold starts arnt that rich. but ill try checking voltage.
Old 06-09-2007, 11:28 AM   #4 (permalink)
rex
Leaky or stuck injector? Does it sound like an old vw bug?
rex is offline   Reply With Quote
Old 06-09-2007, 09:30 PM   #5 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
Is the ECU totally seated in the harness? I had one injector fail because the ecu wasn't seated. It wouldn't fire, and made the other 3 cylinders run pig rich.
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
Old 06-10-2007, 01:40 AM   #6 (permalink)
Gone!!!
Trader Rating: 24 (100%)
I've seen a B13 with a bad ecu that kept an injector grounded which dumped fuel into the cylinder. It actually had fuel leaking out from the header and exhaust. It eventually hydrolocked, bending a rod.
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is offline   Reply With Quote
Old 06-10-2007, 12:51 PM   #7 (permalink)
the proof wizard
thanx guys, but yes. the ecu is plugged in and tight, and ive tested another known good ecu and it still does this?
Old 06-10-2007, 02:33 PM   #8 (permalink)
CAR SLÜT
If you have seen the stock cold start program, it is attrocious. If your getting anywhere around water freezing temp reading from the coolant temp sensor(if it has internally failed or wire has come loose) then it can inject a LOT of fuel.
Old 06-11-2007, 02:31 AM   #9 (permalink)
Technician and Enthusiast
what are the readings you should get for the coolant temp sensor?
Coheed is offline   Reply With Quote
