There have been a couple of threads on spark plugs for the VE. You should get the BKR6E-N plugs, they are specifically suited to the VE. Not sure about the other plugs.
As for low compression, it could be several factors. Bad rings, dirty valve & valve seats, etc. Did you try squirting a bit of motor oil into the cylinders before testing it? If the compression goes up with some oil, that usually means bad rings, or a scored cylinder wall. Either way, low compression on one cylinder is usually not an easy fix I hate to say. As long as it's driving fine though, I don't think it will need to be fixed right away. Good luck!
