Hey guys, my buddies 20ve threw a code the other day, and i for the life of me cant figure out how to check the codes. i have spent quite a while searching the forum for the answer. the ecu is an sr16ve ecu, and it doesnt have the little led and spin screw knob. so i dont know how to check it..
if its the same as the vz-r sr16ve,you link the 2 pins in the top right hand corner of the diagnostic socket for 2 seconds then the codes will come up on the dash,,,,,to cancel out of it link them again for 2 seconds.All you need is a paper clip or a piece of wire.
