Old 06-11-2007, 08:29 PM   #1 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
Hey VE guys, CEL question
I am interested in installing an SR20VE motor in my G20. My G20 is OBDII. The only thing stopping me on this install is my fear of having a CEL. This car HAS to pass emissions in MA.
I know i can use a resistor for the EGR temp.
Are you OBDII guys running this motor with the CEL off? Anything i'm forgetting here?
Dave
Old 06-11-2007, 08:30 PM   #2 (permalink)
myprojectB13's Avatar
Trader Rating: 16 (100%)
You're forgetting that you're putting a VE in a G20. That just can't be fun, keep it stock.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 06-11-2007, 08:32 PM   #3 (permalink)
daveracer's Avatar
It's too SLOW
Old 06-11-2007, 08:33 PM   #4 (permalink)
Broke Ass
jer_760's Avatar
The only cel I get is the cas, because I'm using a b13 tranny.
95 200sx
sr20ve
Old 06-11-2007, 08:34 PM   #5 (permalink)
VE 96 SE-R
just follow the instructions here on the forum and you'll be fine. instead of running a resistor on mine, i ran a modified EGR (VE and DE hybrid) and ran the vacuum lines the way the VE had them and also ran the charcoal canister. (I bought a front clip).
Robert Sousa
http://i17.photobucket.com/albums/b5...-07meet060.jpg
96 SE-R VE goodness
95 G20, couple bolt ons & JDM goodies
SER96VPEC is offline   Reply With Quote
Old 06-11-2007, 08:35 PM   #6 (permalink)
daveracer's Avatar
Nice. I'll be using a b14 tranny, so it should work out.
Old 06-11-2007, 08:40 PM   #7 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
If you are OBD2.
You can just plug in the
EGR selenoid in the harness
EGR sensor in the harness
These 2 just need a resistance reading.
Make sure TPS is set between 48-55
make sure the rear O2 sensor is in the cat.
No CEL will come on
Old 06-11-2007, 08:41 PM   #8 (permalink)
daveracer's Avatar
Originally Posted by Andreas Miko View Post
If you are OBD2.
No CEL will come on
NICE. That settles it then.
Old 06-11-2007, 09:01 PM   #9 (permalink)
eric96ser's Avatar
I put a resistor in the EGR temp sensor, and redid the vacuum lines on the EGR solenoid. No check engine lights for me. Enjoy the swap.
1991 Sentra SE-R
The community is here.
Old 06-11-2007, 09:09 PM   #10 (permalink)
Originally Posted by daveracer View Post
It's too SLOW
I feel ya, I slapped a little turbo setup on mine just to get it up to speed with a B13.
Old 06-11-2007, 09:15 PM   #11 (permalink)
daveracer's Avatar
I *would* do that, but i need this thing to be very reliable.
Old 06-11-2007, 09:22 PM   #12 (permalink)
BTCC VE Power
my jwt has it removed... no cel here
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-11-2007, 09:23 PM   #13 (permalink)
6psi & a JWT ECU has worked for me, of course I do have a VE to drive too.
Old 06-11-2007, 10:56 PM   #14 (permalink)
BnB
drop a stock DET in there. the VE doesnt have enough balls to move a heavy car around. lol.
SR20DEEP CT
SE-Rious@vzw.blackberry.net
91 Sentra SE-R
Turbo
BNB 845 and 860's fastest SE-R's
I <3 old skool
SE-Rious Dino is offline   Reply With Quote
Old 06-11-2007, 11:20 PM   #15 (permalink)
Now accepting donations!!
El Gabito's Avatar
Or you can just get Calum's ECU and delete the EGR and/or rear O2.
My real name is Kyle
El Gabito is offline   Reply With Quote
