Old 06-12-2007, 02:50 PM   #1 (permalink)
SR20VE powered P11 GT
Cam switch wiring question...
When using a VE ECU the cam switches are wired direct in to the ECU and activated by it at pre-set RPM. However, if I activate the cam switches by other means, such as an MMS, do I need still have them connected to the ECU or do I wire them straight into the activator...?
Old 06-12-2007, 03:05 PM   #2 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
you wire them right to the mss and the common wire to 12v+
Check out the last post in this thread for a great picture
http://www.sr20forum.com/neovvl-guid...reddy-mss.html
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-12-2007, 03:39 PM   #3 (permalink)
Very helpful. I figured that was the way to do it. Thanks for the link...
Old 06-12-2007, 03:48 PM   #4 (permalink)
BTCC VE Power
anytime
Old 06-13-2007, 05:02 PM   #5 (permalink)
I might have a go at making one this weekend....
