Old 06-16-2007, 04:33 AM   #1 (permalink)
VE power!
My 2.0 60ft
My drag radials have been slowing me down by the looks of things. I used Falken Ziex's 185/60/14. But my times are still way slower than they should be according to the forum. I also ran with the catback and then straight header with almost no differance at all (less than .070 diff) My friend has been telling me that everyone on this forum is just not telling the truth because this is the internet and they do'nt have to show proof for their bragging rights, and I am starting to think the same. Especially after getting my 2.0 60ft and still having a crappy 1/4 mile time.
100* outside today
60' 2.015
330 6.557
1/8 9.871
mph 86.23
1000' 12.681
1/4 15.073
mph 94.18
If people on here are telling the truth and my car should be doing 13.8-14.2 then something is wrong with my car!
I am going to try and get a dyno run soon. Maybe that will help me find out what's wrong.
Mods: sr20ve super clean and had 210 compression when I tested it.
9lbs flywheel with jgy pp and oem disc
Apexi wai
Ebay stainless header 2" outlet
Calum "basic VE tune"
short shifter
Test pipe
Engine swap parts used: DE maf, VE injectors, DE dizzy.
Car: 92' b13 full interior gutted trunk, stock battery.
E's 92' sr20 is offline   Reply With Quote
Old 06-16-2007, 04:45 AM   #2 (permalink)
Enemy of the stupid
The heat is going to be hell on your car making power. you might want to retune the ecu too. I ran 15.2's in mine with 2.2 60's but I was at a higher elevation which slows n/a cars down .50 in the 1/4 mile. I was also on the stock header at the time.
http://www.3rdgearvtec.net/Andys%20V...R/lacr1524.wmv
http://www.3rdgearvtec.net/Andys%20V...R/lacr1528.wmv
http://www.3rdgearvtec.net/Andys%20V.../lacr15287.wmv
I had alot of problems with my car when I ran those times. I haven't been back to see what it will do now that everything is fixed.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 06-16-2007, 04:53 AM   #3 (permalink)
L337 VVL
Yeah get it on the dyno dude get some afr readings and timing settings tweaked, plus some number to see where you stand.
Done be to disapointed there are alot of forumers still over 14.2 quater times! look at the quater mile thread.
turbofied is offline   Reply With Quote
Old 06-16-2007, 02:30 PM   #4 (permalink)
Broke Ass
jer_760's Avatar
100* outside today
60' 2.015
330 6.557
1/8 9.871
mph 86.23
1000' 12.681
1/4 15.073
mph 94.18
Apexi wai
short shifter
Test pipe
Are you sure that mph is correct
95 200sx
sr20ve
Old 06-16-2007, 02:52 PM   #5 (permalink)
4th sr20 and counting..
zipstrips's Avatar
it sounds to me sometihng is wrong...
i have a ton of slips to comapre with from the convention... heres one that i have cloesest to your time.. i ran a best that day of a 14.8 at 95.05mph... back to on topic, this is my slip, honest and no bs'in you here
closest to your time
R/T... .422
60'... 2.246
330... 6.476
1/8... 9.816
MPH... 73.64
1000...12.679
1/4... 15.088
MPH... 95.40
now my best times slip
r/t .220
60' 2.152
330 6.209
1/8 9.559
mph 73.84
1000 12.438
1/4 14.848
mph 95.05
this is in my 98 stock lowport. you see to climb real slow at your top end, ingition parts good? the VE kicking to hi cam? with that 60' you should be gone.
Racing Calculators
60' to 1/4 Mile Calculator
using this calc. i insert you 1/4 speed,and this is what i get.
60 Foot 1.96
330 Foot 5.65
660 Foot 8.88
660 MPH 76.57
1000 Foot 11.68
1/4 Mile ET 14.07
1/4 Mile MPH 94.18
SHIFT_multiplication!
01. Audi TT 225
98. W10 w/ S4's!
95 Celica, 3SGTE
FOR SALE! PM ME
99. P11 auto $4k
90. Miata $4k
Old 06-16-2007, 06:28 PM   #6 (permalink)
Se-riously???
I don't hear any switchover in the vids, have you dynoed it yet?
I've always wanted a RWD SE-R, maybe after I win the Lotto.
Nismoguy is offline   Reply With Quote
Old 06-16-2007, 06:44 PM   #7 (permalink)
R.I.P Danilo
When I went to the track with stock cams it average 96 to 97 mph in the quarter which is what you are almost at. I would run 14.2 to14.5 time wise. something is not right with the time or speed. OH! and at the eight speed would we between 77 to78 mph.
13.9 1/4 102 mph 2710pounds 201 whp
gio94sr20 is offline   Reply With Quote
Old 06-16-2007, 08:36 PM   #8 (permalink)
the proof wizard
Trader Rating: 26 (100%)
no one is lieing about times. with a 2.0 60ft i run 13.5 @ 100.7. but the only diff is the mph, your car is not pulling as hard as it should, which means your car is not making the power it should. you need to find out whats holding you back, figure that out and your traps will improve. stock cams should be 97+mph
12sec NA
Old 06-16-2007, 08:42 PM   #9 (permalink)
Enemy of the stupid
Your not going to hear any because It was set to 4800 and I was launching at 5500. The car was making 166 back then with a host of problems.
Old 06-16-2007, 08:42 PM   #10 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
What are you using to switch the big lobes on the cams?? MSD??? Summit switches?? GReddy e-mange???
With a 60' like that you should be in the mid 14's easily.
Are you using the stock exhaust also?? This would definetly hurt you.
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 06-16-2007, 09:05 PM   #11 (permalink)
1st thing is you need to find the DA' (density altitude) of the day you went racing. Go to this link and input weather conditions and elevation of the track for that day. This will tell you how much weather is affecting your engine's output. Also looking at your time slip i think something is wrong with the 1/8 mile trap. If ur other time slips look the same, then you must have a car capable of 105-110mph traps lol. I believe you ran closer to 73mph in the 1/8.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 06-17-2007, 03:15 AM   #12 (permalink)
VE power!
I would use the DA' link but I can't even find a site that will tell me about the conditions on June 15, Chandler AZ 85224zip.
I tried running with my stock cat-back and straight header but it did'nt even make a dent in my 1/4 mile times. Almost no differance at all.
My 1/8 mile mph and the rest of my numbers are exactly the same as what it reads on my slip. The 1/8 mile mph's range from 74mph to 86mph on my other slips.
I am using two Summit switches, intake is about 4700rpm's and exaust is 4800rpm's.
Old 06-17-2007, 07:02 AM   #13 (permalink)
CAR SLÜT
I would say the track is in need of a major calibration.
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 06-17-2007, 01:19 PM   #14 (permalink)
Nismo1997's Avatar
Trader Rating: 154 (100%)
What are you shifting at? Are you staying in the powder band? What does your car weight..with you and without? Any dyno #. Cant say people are lieing if your not trying to look into somthing you have in your own hands.
2000 G20
1992 Sentra
2007 Suzuki GSXR 750
Nismo1997 is offline   Reply With Quote
Old 06-17-2007, 04:21 PM   #15 (permalink)
VE power!
The car has nothing in the trunk and no other wieght reduction other than that. I had a 1/4 tank of fuel at the time. So I'm guessing the car wheighs about 2450 plus me 135 that should put the car at around 2585lbs. I am shifting at 7500-7600rpm's, any higher and my times become slower.
I will try to schedule a dyno run this week.
Old 06-17-2007, 04:51 PM   #16 (permalink)
Broke Ass
jer_760's Avatar
Im not trying to say you are lying, but there is no way you are running 86 mph 1/8th with those mods and full interior. 74-76mph would be about right.
Old 06-17-2007, 05:06 PM   #17 (permalink)
VE power!
Old 06-17-2007, 06:02 PM   #18 (permalink)
R.I.P Danilo
Some thing is really wrong there. When I was boost I ould trap 86-88 in the 1/8 and at the 1/4 it would register at 116 to 119 mph. Check that out. The track may have done an arror.
Old 06-17-2007, 06:23 PM   #19 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
That doesn't look right at all. At 1200 ft amsl and 100 degrees F you certainly aren't gonna see those 13.8s with that rig.
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
