Old 06-16-2007, 05:34 AM   #1 (permalink)
I <3 VVL
Avenir turbo setup on a VE?
Has anyone tried this yet? Just putting all the stock turbo parts onto the VE? Would the ports bolt up(could you port match the exh. manifold?)
Let me know if anyone has tried this or if its not possible for any reason. I did search the VE forum and didn't find a whole lot.
98 Sentra SE VVL
Tonyklem is offline   Reply With Quote
Old 06-16-2007, 10:13 AM   #2 (permalink)
stock suprise
search Bigjohn. he ran a T25 @ 7lbs and i believe he made around 235whp. then he went with a T28 (GTiR) turbo and made 250-260ish whp. still on 7 lbs i believe.
96 200SX- JDM SR20VE, JDM N1 red valve cover, SE-L's, hotshot wai intake, headers, 2.5 exhaust, 11lb flywheel, comp clutch 6 puck sprung disc, short shifter, nismo leather shiftknob, tokico struts, tein springs, black housing headlights, black corners with amber.
I :heart: my B14
Originally Posted by Serban
That's why women shouldn't be allowed to drive. It all went down hill after they got the right got vote
p0keyb13 is offline   Reply With Quote
Old 06-16-2007, 11:51 AM   #3 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
238.8whp with a basic Avenir setup. Very impressive.
http://www.sr20forum.com/sr20ve-sr16...-manifold.html
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 06-16-2007, 05:11 PM   #4 (permalink)
No soup for you
Trader Rating: 30 (100%)
I ended up with almost 245 whp with a little tuning and bringing the cams on later. The cars is still running to this day, same t25, same tune.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 06-16-2007, 06:36 PM   #5 (permalink)
R.I.P Danilo
We recently did a de/ve T-25 turbo. AT 12 Pounds of boost it made 302 whp past 7000 rpms. Car runs very strong worth every penny. DO IT.
13.9 1/4 102 mph 2710pounds 201 whp
gio94sr20 is offline   Reply With Quote
Old 06-17-2007, 07:31 PM   #6 (permalink)
G20style.com
John
this is on a stock VE?? no compression changes or anything?
Visit My site WWW.G20style.COM for Custom G20 products
Ericdd is offline   Reply With Quote
Old 06-17-2007, 09:14 PM   #7 (permalink)
I <3 VVL
Ok, so what all does a complete avenir setup consist of.
What all would I need to add or swap out to make this work the best (with reasonable cost).
Im not really looking to boost more than stock for now (maybe 10psi max later on... this is my daily)
Here is my setup:
-Stock SR20VE
-JWT ecu with VE program (rev limiting at 7100rpm ...)
-Fuji headers back to 2.5" mandrel exhaust
-MSD-8671 RPM switches (1 for each cam)
-I may have left some stuff out, I kind of have a mind block right now.
Anything that isn't mentioned is probably the stock VE setup, but mention it if its important.
Old 06-17-2007, 10:48 PM   #8 (permalink)
merely a flesh wound
chriscar's Avatar
It's no different than turbocharging a DE. Check out the turbo install writeups on the forum.
