How did you find 16ve cams in 20ve do you lose any torque in low rpm i am sure you will get more hp in top end also did you just fit it straight in without mod
I've got the cam switches jerry-rigged through a switch on the dash at the moment, but not rally used it yet. The SR16 cams feel good, she definatly seems to climb th revs quicker then the DE did, however only a dyno is gonna tell the truth...
BTW, the SR16 cams were a straight swap. No messing..
