Old 06-16-2007, 12:06 PM   #1 (permalink)
AKA-- JJKAMIKAZE
thermostat
is the thermostat the same in our VEs as a DE. my housing is leaking so i figured i might as well upgrade to a nismo thermostat. its hot as hell here and the winters are mild so i dont really need a stock style thermostat, and i plan on tracking this car soon.
NismoTheDog is offline   Reply With Quote
Old 06-16-2007, 02:04 PM   #2 (permalink)
The Genesis
yeah, the de is interchangeable
Old 06-17-2007, 04:09 AM   #3 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
i got a nismo in my ve.. it says it on the box sr20de, ve and some others
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-17-2007, 04:21 AM   #4 (permalink)
VE power!
What makes the Nismo thermostat better?
E's 92' sr20 is offline   Reply With Quote
Old 06-17-2007, 06:57 AM   #5 (permalink)
CAR SLÜT
Opens at a lower temp and also flows more water, so less restriction on the water pump as it it not 'pushing' water as hard
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 06-17-2007, 07:38 AM   #6 (permalink)
Does anyone have the part number handy? Sounds like a good mod for any track car.
Old 06-17-2007, 08:37 AM   #7 (permalink)
CAR SLÜT
Apparently, Nismo outsource their thermostat's production/design to an actual thermostat manufacturer.
I personally use the Tridon brand thermostat(Tridon also make hose clamps) and costs the same as a stock thermostat.
Quote
Tridon Australia now offers a High-Flow Thermostat to improve cooling
system performance. High-flow thermostats have a larger valve (Fig.l) and
allow approximately 30% more coolant to flow to the radiator than standard
type Thermostats. Using High Flow Thermostats eliminates any need for
using cooler temperature Thermostats as a temporary cure for overheating
problems as was done in the past. Using correct High Flow Thermostat at
correct temperatures specified by OEM manufacturers will not interfere with
the engine management system.
All High-Flow Thermostats are fitted with a jiggle pin that enables the system
pressure to be stabilised so that the valve opens easier. The jiggle pin also
allows air pockets to move past the Thermostat and the temperature to be
regulated more efficiently. Fitting High-Flow Thermostats will allow your
vehicle cooling system to operate more efficiently.
Old 06-18-2007, 12:21 AM   #8 (permalink)
where do you get those thermostats?
dudeman
Looking for a shell
1991 SE-R
Old 06-18-2007, 01:08 AM   #9 (permalink)
CAR SLÜT
I can send the Tridon ones to you guys for my supply/cost price(US$25 + international express courier delivery of US$35) if necessary.
Old 06-18-2007, 01:19 AM   #10 (permalink)
L337 VVL
Or if you guys want the very best there are the billion t stats,
http://www.gccorp.com.au/automotive/...roducts_id=271
Expensive(Still nothing compared to what some spend on performance parts) but a very high quality.
turbofied is offline   Reply With Quote
