Old 06-17-2007, 08:23 AM   #1 (permalink)
SR20VE powered P11 GT
Erratic misfire problem...
I'm getting a misfire on the VE that's proving a problem to track down. My current set-up is; SR20VE engine, SR16VE cams, 265cc injectors, DE ecu, DE MAF. I'm currently running just on the low cams so in theory, it shouldn't be much different from a standard DE set-up. However I'm getting an erratic misfire on one cylinder. The plug is getting sooty which suggests it's running rich. The other three are ok.
Originally, it was on cylinder No. 3. I've swapped the plugs, leads and dizzy with no effect. Yesterday I swapped the injectors and now the mis-fire has moved to cylinder No. 4.
I'm suspecting the fault my lie with the injector. Anyone got any thoughts...?>
Old 06-17-2007, 08:49 AM   #2 (permalink)
CAR SLÜT
The stock SR20DE injectors are extremely common for leaking. I have about 10 injectors sitting in a box that leak fuel at anymore than 30psi of fuel pressure.
Try and find another single injector
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 06-17-2007, 09:49 AM   #3 (permalink)
No soup for you
Trader Rating: 30 (100%)
It may just be the o-ring and not the injector. Either way, its sounds like you've narrowed the problem down. Best of luck.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 06-17-2007, 10:48 AM   #4 (permalink)
Do you mean the large 'o' ring that sits between the injector and intake manifold? If so, I checked them too. The mis-fire has changed cylinders from No. 3 to No. 4. Only thing that moved across was the injector...
Looks like I best look for a spare injector...
Old 06-17-2007, 10:55 AM   #5 (permalink)
No soup for you
I'm speaking of the o-rings on the injector. If you are not aware of them it is more than likely your problem, as they should be lubricated when installing the injector. These o-rings manage the fuel, so that only fuel from the pintle enters the cylinder when the injector is fired. If the o-ring is torn or leaking, then you have unwanted fuel entering the cylinder causing a rich condition. The extra unatomized fuel will flood the cylinder and cause the misfire.
John
Old 06-17-2007, 01:36 PM   #6 (permalink)
Right, the problem is the injector. Fuel is running either through it or past it all the time, flooding the cylinder... I've just had the plugs out again and there's a swimming pool of fuel in the mis-firing cylinder...
I'll take the injector out of the fuel reail and check the rings...
Thanks...
Old 06-17-2007, 01:43 PM   #7 (permalink)
Got the injector out infront of me...
It's the left one We're talking about. there is a large 'o' ring that fits around the time of the injector, just below the red cap. There is then a second 'o' ring that sites between the lower black ring and the white cap at the bottom of the injector.
On the one in front of me, the lower ring is damaged. Would this be the cause of the fuel flowing through it....?
Old 06-17-2007, 01:55 PM   #8 (permalink)
rex
YES!!! Leaky injector.
rex is offline   Reply With Quote
Old 06-17-2007, 02:00 PM   #9 (permalink)
I've replaced the ring and refitted the injector into the rial rail. After the GP has finished I'll charge it up and see if thats fixed it...
Old 06-17-2007, 02:03 PM   #10 (permalink)
rex
Did you lube the oring? A little vasoline will let the injector go without ripping the oring.
Old 06-18-2007, 01:19 AM   #11 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
this is so common on turbo swaps more so than ve's cause ve owner tend to keep the same injectors
anyway hope this fixes your issues
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-18-2007, 08:18 PM   #12 (permalink)
CAR SLÜT
For future reference:
The top o ring stops the rail pressurised fuel from squirting out around the red cap. The bottom o ring stops fuel from flowing in/around the pintle. Between the two o rings, the injector is pressurised by fuel rail pressure and is directed down the injector body.
