Old 06-18-2007, 02:01 PM   #1 (permalink)
Trader Rating: 36 (100%)
Help with Greddy MSS Acronyms
It would be easier to figure out how to configure the Greddy MSS if i actually knew what the acronyms mean. Anyhow, please add to the list or correct me if i'm wrong.
SP - Sensor Position
P2 - Pulse 2 - Speed Sensor
Vo - TPS Voltage
C4 - 4 cylinder
Bo - Boost
7P
Pr
S1 - solenoid 1
S2 - solenoid 2
Temp, rpm??
99 sentra se-l
t25 turbo part out:
http://www.sr20forum.com/forced-indu...isc-parts.html
iczer200sx is offline   Reply With Quote
Old 06-18-2007, 02:37 PM   #2 (permalink)
this are the settings...
VO_
C4-
P2_
1)ON
2)ON
papakias is offline   Reply With Quote
Old 06-18-2007, 02:52 PM   #3 (permalink)
i know the settings. i want to know the acronyms so i understand the settings...
Old 06-18-2007, 03:41 PM   #4 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
http://www.sr20forum.com/neovvl-guid...reddy-mss.html
1991 Sentra SE-R
The community is here.
Old 06-18-2007, 05:10 PM   #5 (permalink)
wow, let me be even more specific here. my mss is configured, wired up, and the solenoids activate the high lobe cams. i just wanted to know what the acronyms stand for in the mss settings. for example, Vo means TPS voltage. I've searched the forums and couldn't find an answer.
Old 06-18-2007, 08:31 PM   #6 (permalink)
AKA-- JJKAMIKAZE
you have to run the wires from your MSS to the solenoids. then you have to run the other solenoid wires to 12v.
just kidding . im looking for my manual so i cant translate it for you.
NismoTheDog is offline   Reply With Quote
Old 06-19-2007, 05:16 AM   #7 (permalink)
banned
Trader Rating: 23 (96%)
Vo - TPS Voltage
C4 - 4 cylinder
Bo - Boost
7P
Pr
S1
S2
Temp, rpm??
s1= solenoid 1
s2= solenoid 2
dont remember the other 2
G-Unit91 is offline   Reply With Quote
