Old 06-16-2002, 03:22 PM   #1 (permalink)
converting sr20ve to rwd
is it possible to make the sr20ve rwd i ahve seen a 240sx with a sr20ve on the net but how ahrd would this be would it just be a matter of changing the flywheel to a rwd flywheel?
thanks
madmoney is offline   Reply With Quote
Old 06-16-2002, 04:39 PM   #2 (permalink)
I would think youd have to use the bottom half of a rwd det and just use the head of the sr20ve.
Mindset is offline   Reply With Quote
Old 06-17-2002, 02:44 AM   #3 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
the 240's transmission should bolt right up to the engine, with no problems
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-17-2002, 09:54 AM   #4 (permalink)
爆走
its been done already. there is a company here in japan that does it, but not sure if it is a conversion or an authentic rwd ve. there are lots of strange models of the s15 and i heard from somewhere that one had a ve in it but who knows if that is really true? from the photos i saw it looked clean but it was running a standalone Apexi computer with velocity stacks and no maf.
Old 06-17-2002, 11:14 PM   #5 (permalink)
爆走
http://www.ne.jp/asahi/eagle/racing/newpage4.htm
sorry, its not Apexi its an hks f-con v. it has to be done with the silvia ecu and DI system unless you cut a big hole in the firewall for the distributor. it is just a ve head swapped onto a de block. they are also running 12:1 with no problem.
