Old 06-22-2007, 12:25 PM   #1 (permalink)
2.0 crank
I dont want to disturb the 4 counter vs 8 Counter crank topic
wondering on the 2.0 crank weight
in my hand i have the following crank
GTiR crank
20VE crank
2.0DET or DE if i can get DE 8 counter crank
which one is preferable crank for high reving 2.0 VVL ? 9k rpm limit ?
friend mention GTiR crank more suitable for Turbo instead of NA application
Arrhh
cmng is offline   Reply With Quote
Old 06-22-2007, 12:41 PM   #2 (permalink)
Baby Blue VVL
it doesn't matter
I would say it matters more that which ever crank you use make sure you get the ENTIRE bottom end balanced
FYI i run a balanced GTIR crank
VVL?
IX MR?
A race????
Old 06-22-2007, 12:52 PM   #3 (permalink)
Of course ..
that the headache here since i need to send all the item to balancing work
it just the matter which crank to decide only
Old 06-22-2007, 12:59 PM   #4 (permalink)
Luke Pighetti
Taiden's Avatar
I frankly don't understand how a balanced 4 cw crank could be worse on bearing life than a balanced 8 cw crank... assuming they are all balanced to the same variance specs...
I don't build motors though, so I could definitely be wrong.
Old 06-22-2007, 01:13 PM   #5 (permalink)
Technician and Enthusiast
I put a 8cw crank in the VE-T. It came out of a DE. It didn't require any balancing with the pistons and rods. At least that is what I was told. The pistons and rods were zero balanced when they got to me, and the crank was still perfect so I just threw them all in.
Coheed is offline   Reply With Quote
Old 06-22-2007, 01:27 PM   #6 (permalink)
i not sure what the cost at US
but at here full balancing cost is around USD 150 only
for all the item below
Flywheel
Crankshaft
Piston
Rod
Main , water pulley
Old 06-22-2007, 03:07 PM   #7 (permalink)
Baby Blue VVL
in the US it's about the same price
Make sure they also include the rod bearings as well.
Mine was about $90USD
Crank
Flywheel
Pulley
Rods
Pistons
Rod bearings
Old 06-22-2007, 04:11 PM   #8 (permalink)
Professor Dingbat
It's not about balance. You could have a crank with zero counterweights that is perfectly balanced. That doesn't mean it would be OK to use though...
Old 06-22-2007, 04:20 PM   #9 (permalink)
as i have read it is more about harmonics, but i am not in full understanding of this, but genrally lighther is not always better........
anomaly is offline   Reply With Quote
Old 06-22-2007, 04:22 PM   #10 (permalink)
Care to elaborate?
Looking for a shell
1991 SE-R
Old 06-22-2007, 07:59 PM   #11 (permalink)
You have to look at the flex of the crank. When spinning at thousands of rpms a half-counterweighted crank will have more flex because of the impalance. It makes sense right? The weights are there to counter the weight of the pistons and rods, obviously having half the weight to counter would cause balance issues. If it didn't, then no crank would have any weights at all.
Old 06-22-2007, 08:13 PM   #12 (permalink)
Luke Pighetti
Taiden's Avatar
Yeah, that is why I speculated and said I wasn't sure.
Is there anyone on here that can speak to the raw mathematics of it all?
Old 06-22-2007, 08:44 PM   #13 (permalink)
ooo, raw mathmatics...yumm
Old 06-22-2007, 09:39 PM   #14 (permalink)
Baby Blue VVL
Originally Posted by bigtoe
Folks,
From what I have seen the Bearing Beam (Girdle) holds the crank in the plane parallel to the main bearing centerline. Because the Block is a deep skirt design there is no need for a Girdle (by definition: main caps part of the assembly).
It is proven that the combination of deep skirt, registered main caps, a bearing beam and a torsional "external mass" damper gives the best overall control of crank vibration.
This is the method Nissan used on the SR20 for noise and vibration control, by extension it gave rise to a rock solid bottom end.
The discussion on 4 vs 8 CTW is a nice one. From what I have seen with my motors and others;
The 4 CTW tends to "vibrate" the NO.4 Main Cap and bearing.
The effect of this is seen on the NO.3 Rod Bearing.
I have not seen evidence of the same on the 8CTW.
I have felt the 4CTW come through a distinct harmonic for a very brief period in the rev range (solid mounted motor and solid all welded chassis).
There is also another thing that happens on an inline 4 motor and that is the fact that on this engine combination two cylinder fire right next to each other (3 and 4). What happens here is that by extension from the leverage forces of the rod journal, the Main journal between the two is twisted at a very high frequency from the unloading of one (exhaust stroke) to the re-loading of the same (power stroke on the other). It typically manifests itself on main bearing NO.4. This is something that every V configuration motor has to take into account in their crank designs (like Porsche got wrong on the first generations of the 928 V8 Motors). There is a lot more to this discussion because the only time it is evident is when the motor is "fired" and live under load, and not static for an imperical calculation on balance of individual components.
My recommendation would be for an 8 CTW for a car that will be pulling through a fairly wide rev range.
Now SUMITUMO under financing of various japanese OEMS studied the dynamics of 4 vs 8 CTW cranks and actually came up with the 4 CTW being better for any specific 4 cylinder motor. HOWEVER, the counter weigts are not egual mass in their design. SUMITOMO was chosen because they make the bulk of the Japanese crankshafts.
Again from my own experience: The Bearing Beam takes power away due to windage in the crank case and obstruction of the attomised oil around the crank. I have not seen this on my Dry Sumped negative pressure sump motor.
Later tonight I will post the two SAE Paper numbers for the crank design and for the vibration analysis on four cylinder engines for any one interested.
/thread
Old 06-22-2007, 10:41 PM   #15 (permalink)
rod bearing ?
emm interesting since all the time i never seen this rod bearing included inside the balancing list
basically i receive a lot feed back from friend after balancing the engine internal
the engine rev smoother and feel light..
a big different and worth to do it
this is balancing only.. not lightening.. not intend to lightening
i think i will go with GTiR crank option
Old 06-23-2007, 06:56 AM   #16 (permalink)
Ol' Dog
Originally Posted by OnyxEros View Post
/thread
The 3 & 4 cylinders fire together? That sounds really bad even in the tightest of tolerances. What benefit would an engine have with that config? Maybe I`m just visualizing this the wrong way.
`93 Sentra SE-R (stock)
Sr20ryda is offline   Reply With Quote
Old 06-23-2007, 09:05 AM   #17 (permalink)
N14 racer
The reason for the crank flexing at high RPM with the 4CW crank is that Although the counter weights do offset the weight of the piston and rods, they are not in the same plane. The counter weights sit off to the side of the con rod to allow it to clear. With the 4CW crank, each piston only has a counter weight on one side only, which causes a slight bending moment as the asembly rotates. The 8CW crank has a counter weight on each side of the con rod which helps to balance any bending moment.
Slack is offline   Reply With Quote
