Old 06-23-2007, 11:03 PM   #1 (permalink)
SR20DEEP N.Y.C.
greddy mss locations
all you greddy mss users, i need your help. i think i made up my mind to get 1....i have a couple frinds that have switched over from the msd...to the greddy....and they love it. i wanted some location ideas....if you guys could post some pix...of where you mounted your mss boxes that'll be great. also...where's the best place to get 1? i tried ebay, and believe it or not...they dont even have 1. thanks in advance for you guys help
SR20DEEP N.Y.C.
LOCK IT UP!
DEAD SE-RIOUS is offline   Reply With Quote
Old 06-24-2007, 12:02 AM   #2 (permalink)
AKA-- JJKAMIKAZE
i put mine in my glove box. just drilled a litte hole in the back of the glove box for wires and put a rubber gromet in it. got mine from JGY they had it to me the next day, i only had to listen to them make fun of my street address name for 10 min.
NismoTheDog is offline   Reply With Quote
Old 06-24-2007, 01:51 AM   #3 (permalink)
12's Is So Last Summer!
urbanracerone's Avatar
Trader Rating: 36 (100%)
What did they love compared to the MSD? I'm curious, does it do somthing the MSD don't do?
JUN
turbo SER's are so 90's!
Tarmac Motorsport LLC
89-Florida St
farmindale NY, 11735
631 390 9410
NYC's Fastest Nissan's
urbanracerone is offline   Reply With Quote
Old 06-24-2007, 04:24 AM   #4 (permalink)
SR20DEEP N.Y.C.
JUN
when you see em in the streets....ask em
Old 06-24-2007, 10:32 AM   #5 (permalink)
llaprad1's Avatar
I lower my points so that my revs don't dip below the activation points on tracks with loose surfaces.
Or you could also set de-activation at a different RPM than activation. Or have it WOT-dependant.
Louis - 1991 Nissan Sentra SE-R w/SR20VE
09 SR20 Calendars available NOW!
Limited Time: SR20VE Stainless Steel Badges
llaprad1 is offline   Reply With Quote
Old 06-24-2007, 11:06 AM   #6 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
On my NX:
Old pic, but the location hasn't changed:
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 06-24-2007, 12:54 PM   #7 (permalink)
SR20DEEP N.Y.C.
^^^ i like that 1, looks good. very neat, easy to get too.i have a b14 ***....not sure if that'll work the same for me...but gonna look into that. thanks for posting the pic bro
Old 06-25-2007, 04:20 AM   #8 (permalink)
Ok thanks you for your response, I see you have a good reason for switching to the MSS.
JUN
Old 06-25-2007, 11:23 AM   #9 (permalink)
SR20DEEP N.Y.C.
JUN
yup the best reason ever......cause i feel like it sorry if that doesnt make to much sense to you....but thats the point. its all about me....but tell you what...when you frontin the cash for whatever parts "I" want.....then and only then will i take your feelings into consideration Now moving right along.....do you know a place where i can get 1 at a decent price?
Old 06-25-2007, 01:03 PM   #10 (permalink)
llaprad1's Avatar
Tons of places have them for around $140-160.
Old 06-25-2007, 01:11 PM   #11 (permalink)
the proof wizard
Trader Rating: 26 (100%)
JUN
im not sure i see any reason people would be switching either??? i just use the msd rpm activated switch.... it switches the cams, thats all i care
12sec NA
Old 06-25-2007, 01:32 PM   #12 (permalink)
Me likes Big Ol Booties!
What's the name of your street?
2001 SE Auto...SR20VE-T, info in cardomain page
1993 Infiniti G20...acquired at 214k miles, original motor, going strong
http://www.cardomain.com/ride/1675260
mirrortints is offline   Reply With Quote
Old 06-25-2007, 03:43 PM   #13 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
not everyone wants to be a street/track racer..
Reasons why Greddy MSS is better:
1. 2 Separate activation points (more power under the curve smoother ride overall)
2. TPS activation (in case your car is a daily driver and you dont want vvl kicking on all the time) saves gas
3. Speed activation (VTEC works with tps, and speed as well as other parameters, so you dont activate it in 1st gear) saves gas
4. Small lightweight display, easy to mount in the car... shows all the parameters you have hooked up, speed, rpm, tps position, etc
Cons vs MSD:
1. cost more
2. not as easy to program and install
3. ....?
KL0 P11 Sport
Surround Sound
My VE thread
Old 06-25-2007, 04:59 PM   #14 (permalink)
SR20DEEP N.Y.C.
Cons vs MSD:
1. cost more
3. ....?
god bless you brother. thank you for posting some of the pro's and cons. but to be honest...i just like the display, and i can get to the mss without going under the hood. i'm still not sure why any of that matters.....i just want the greddy mss. simple. but that info you posted was very usefull as i didnt know a few of those points....just makes me want it even more now. thanks again
Old 06-25-2007, 05:05 PM   #15 (permalink)
Cons vs MSD:
1. cost more
3. ....?
I'm not going to argue with you, because you drive a P11!
JUN
Old 06-25-2007, 05:07 PM   #16 (permalink)
JUN
Old 06-25-2007, 05:09 PM   #17 (permalink)
WASHED UP
JUN
JUN
Old 06-25-2007, 05:21 PM   #18 (permalink)
eric96ser's Avatar
Cons vs MSD:
1. cost more
3. ....?
I'm using the old school MSD boxes and I have separate activation points. I'm not worried about using more gas by having the cams switch in 1st gear. I just don't rev high enough in that gear for the cams to switch. The rpm boxes are so much easier to program. I remove the pill and insert a new one. If that is difficult for someone to do, then they need to take their bicycle to work, but then again, that has confusing gears to deal with. I like the MSD boxes better. Set it and forget it, but then again, I'm not a street warrior and need to lower my cams to change at 2k rpm for street cred, nor do I care about the display.
1991 Sentra SE-R
The community is here.
Old 06-25-2007, 06:27 PM   #19 (permalink)
rex
Cons vs MSD:
1. cost more
3. ....?
3. No digital display of idle under the hood - would be great for setting timing.
4. Need to add relays.
5. Blingier, alright if you want your windows broken.
rex is offline   Reply With Quote
Old 06-25-2007, 06:30 PM   #20 (permalink)
AKA-- JJKAMIKAZE
i like the mss mainly because you can change the peramiters whenever you want from inside your car in under 10seconds. its the easiest interface possible.
