Old 06-25-2007, 05:34 PM   #1 (permalink)
On Vacation
Headgasket question
Can I use a stock VVL headgasket on 87mm VVL block?
Manny E.
523 whp & 409 wtq ---RETIRED
SE-Rawkus is offline   Reply With Quote
Old 06-25-2007, 06:30 PM   #2 (permalink)
Out of business
Trader Rating: 44 (100%)
try getting the VET gasket machined out to 87mm
In Loving Memory of ZAD,We LUV Ya ta Death, Save us a Spot Next To Ya Up There, we'll see you soon
He can make 200,250 or even 300whp! Because at the end of the day, He's not going no where but up and down Liberty Avenue stuntin for the rest of his fellow Indian friends!
If ya want JDM go the fu_k to Japan
4Doors and not 2 are the real Sunny's
RE-Spect is offline   Reply With Quote
Old 06-25-2007, 07:51 PM   #3 (permalink)
On Vacation
I would really like to find this out.
Some of the motor heads on this forum said you can use a VE headgasket with a 87mm bore motor (VVL) but I really want confirmation on this before i purchase a headgasket I won't be able to use. There wasn't too much discussion in the following thread...
http://www.sr20forum.com/sr20ve-sr16...bore-size.html
Old 06-25-2007, 07:56 PM   #4 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Some of the motor heads on this forum said you can use a VE headgasket with a 87mm bore motor (VVL).
I measured a 20V gasket and the inner bore was 86.5mm but the sealing ring was still alittle bit inwards so I think it might work but not 100% sure.
The cometic is good. but the ARP bolts are not up to the task. Thats were the problem is.
Old 06-25-2007, 11:14 PM   #5 (permalink)
Out of business
so what head bolts do you recommend
Old 06-26-2007, 04:43 AM   #6 (permalink)
VVL Junkie
can I use
VVL Metal Head Gasket (which Greg sells) with bigger than 86 mm bore.
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
