Old 06-26-2007, 12:38 PM   #1 (permalink)
JN15
SR16VE/20VE Conversion
I have a SR16VE and a SR20VE. I want to use the SR16VE head on the SR20VE btm. How do I make this conversion work? What are the necessary parts that I will need? I also am using this car as a daily driver.
SunnyVZR is offline   Reply With Quote
Old 06-26-2007, 12:40 PM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Why do you want to do so they are the same heads
Old 06-26-2007, 12:43 PM   #3 (permalink)
Luke Pighetti
Taiden's Avatar
just swap the cams
Old 06-26-2007, 12:43 PM   #4 (permalink)
I cruise @ your top speed
Take the SR16VE cams and put them in the SR20VE head.
Good to go! IIRC the to heads are the same....
-Ryan-
'91 Hardtop NX2000-SR20VE
Originally Posted by 1NonlyDave
What in the world do you have done to your SE-R? Has to be quite alot to beat the K20Z3 that bad.
Originally Posted by mannytheman1257
its the k20s nightmare...VVL lol
NismoSR20 is offline   Reply With Quote
Old 06-26-2007, 12:47 PM   #5 (permalink)
the proof wizard
Trader Rating: 26 (100%)
maybe he has put some money, or a lot of work into his head. so since they are the same there is nothing specialy, just put the head on your 2.0ve bottom end
12sec NA
Old 06-26-2007, 01:47 PM   #6 (permalink)
JN15
Well, I heard that If u were to place the sr16ve head on the sr20ve block you would see some good hp gains, is this true? Wouldnt it be similar to those honda's that have the b16 on a b18 ? Also I have the SR16VE in my Lucino VZR already and my frend has a primera TE-V that I am gettin the SR20VE block from b/c he is going to reuse his old SR20DET GTiR motor. Also I was wondering if there is any real difference between the Autech version SR16VE and the normal one, because my Lucino is the Autech version and it has a sticker on the valve cover nex to the Neo Vvl sticker that says E-JN15 autech and then a bunch of jap writing... heres a pic of my motor.
Old 06-26-2007, 01:52 PM   #7 (permalink)
JN15
Old 06-26-2007, 01:55 PM   #8 (permalink)
Jah Rastafari
This is not true.
The SR16VE head and SR20VE head are the same.
If you have a SR20VE just put the SR16VE cams in it.
This is not a Honda so dont base Honda facts on a Nissan.
Old 06-26-2007, 02:30 PM   #9 (permalink)
JN15
Hmm ok thanks. another question is *** is there any differences between the Autech verison SR16VE and the normal SR16VE? What should I do to my SR16VE then, performance wise? does it make sense to mod it? should I turbo it?
Old 06-26-2007, 02:41 PM   #10 (permalink)
Jah Rastafari
I dont think there is an Auteck SR16VE
There is an Auteck SR20DE with 175hp
Now there is 2 diffrent SR16VEs
N1 SR16VE with Burgandy valve cover 200 HP
This motor comes with
ported head and head is shaves 1mm
Bigger Cams
11.8 to 1 compression
70mm TB
Larger intake Plenum with slightly shorter runners
SR16VE with Blue valve cover 175 HP
11 to 1 compression
smaller cams than N1 but bigger than regular SR20VE
Old 06-26-2007, 02:49 PM   #11 (permalink)
JN15
Ahhh alright thks. Well i guess all thats left for me to do to the 16VE is make it into a "N1" along with getting some headers and fine tune the ECU. As for the Autech verison.
Old 06-26-2007, 02:51 PM   #12 (permalink)
Jah Rastafari
Well you can start by getting intouch with Greg V at G Spec Peformance at the bottom of the page.
He can get you the N1 cams and the complete N1 intake manifold.
Old 06-26-2007, 03:56 PM   #13 (permalink)
Travieso Racing
autech sr16
hmm take a closer pic of the plaque on the vc next the NEO VVL POST PICS OF THE JAPANESE writing i think we can get it translated.
if it is an autech.. i would rethink about takin the motor apart.. rarity wise only.
Danny GDM (HKS)
1993 PRiMERA GT
Old 06-26-2007, 03:59 PM   #14 (permalink)
Jah Rastafari
The Autech stickers could be for the body kit and the white face guages.
I have never heard off an Autech version SR16VE.
Andreas Miko
Old 06-26-2007, 04:05 PM   #15 (permalink)
JN15
Thats what I was wondering ill give you a close up pic of the writing when I get home.
Old 06-26-2007, 05:45 PM   #16 (permalink)
giggidy giggidy
I too, have an Autech VZ-R. I can assure you they didn't touch the internals of the engine. The ecu maps are exactly the same as a normal VZ-R (we even downloaded them for a comparison). They do have a real nice bodykit, a rad interior and a sporty exhaust but apart from that, there's no real difference. I'm with these guys, put your SR20VE in with the SR16VE cams and some 370cc injectors, slap your blue rocker cover on there and away you go.
Anybody who cannot comprehend mathematics is not fully human. At best he is a tolerable subhuman who has learned to wash, cook food, and not make messes on the floor.
punkoutnz is offline   Reply With Quote
Old 06-26-2007, 10:40 PM   #17 (permalink)
Autech ?
I thought N1 is produced by Nissan Autech Division ?
Arrhh
cmng is offline   Reply With Quote
Old 06-27-2007, 06:38 AM   #18 (permalink)
Very Very Loud too!
D*mn! Now i'm dissapointed...My SR16 also comes from an Autech N15...
And i have an identical instrument panel...
Nikiforos-P10 is offline   Reply With Quote
Old 06-27-2007, 08:05 AM   #19 (permalink)
VVL Junkie
what is the stock sr16ve tb size? May I use tomei 70mm tb or N1 is better? Greg's N1 tb is 3in~76 mm on the picture. It's bigger? The tb square increment is sufficient!!! more than a 50%.
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
Old 06-27-2007, 08:33 AM   #20 (permalink)
Jah Rastafari
stock TB size is 60mm This comes on SR16VE and SR20VE.
Get the N1 TB
The N1 TB is 70mm at the plate. The mouth of the TB is 76mm
