I am using an AFC Neo on my SR20VE for fuel management, and I've tested the VTEC controller output with a multi-meter while I was at it on Sunday. I can tell you it works just fine, even with the input fully disconnected. The output would go up to around 12V at the set RPM like clockwork. I can hear the solenoids getting activated with that setup no problem, and the function is accessible in the menu even with the input disconnected.
So, basically, you wire up the VTEC output (pink) wire to one wire of the solenoid, and the other solenoid wire to a 12V source. I jumped the signal to both solenoids, as the AFC Neo only has one ouput. You keep the VTEC signal input unconnected. I believe the AFC Neo uses it only to correct the fuel maps if you set your solenoids to fire up at a higher RPM than stock on a VVL/VTEC ECU. With it unconnected, it just thinks that the "stock ECU" never fires up the solenoids, which is no big deal.
It's a great option, IMO, since you get both fuel management and RPM switch functionality in just one unit.
Matt
2001 Sentra SE/pp (SR20VE powered)
