Old 06-27-2007, 02:15 PM   #1 (permalink)
Andreas Miko
Jah Rastafari
Trader Rating: 54 (100%)
Please Read If You Are Going To Order Head Gaskets
There are many people who have ordered head gaskets from Cometic and have gotten the wrong Part. This has happened to Manny SE-Rawkus.
There are 4 basic headgaskets that can be had at Cometic.
If you call them and ask them for the headgasket with the xtra hole in the back you will get the wrong gasket as there is another gasket from the SR20 family that runs an xtra hole, which is the S14 head gasket. Alot of guys are calling their S14 and S15 motors VE or say it has VTEC so they get the wrong gasket.
Anyway.
All SR20VE motors SR16VE, SR16VE N1, SR20VE, SR20VE 20V and SR20VET.
Part number starts H1794
All SR20DE motors FWD SR18DE, SR20DE, and SR20DE RR
Part number starts CM-C41
All S13 SR20DE and SR20DET
Part number starts C4324
All S14 and S15 SR20DE and SR20DET
Part number starts C4285
Old 06-27-2007, 02:34 PM   #2 (permalink)
Andreas Miko
Jah Rastafari
Please make this a sticky. I have worked with Cometic on this and I am trying to get these gaskets down to 3 parts.
I have to send out a few gaskets to them to finish up these problems. They still dont get that the DE and VE FWD gaskets can be interchangable.
I told them if they just make the VE headgasket design it would work with the DE no problem.
Old 06-27-2007, 02:37 PM   #3 (permalink)
rigged200
VE POWWA
Good looking out Andreas......yes definitely make into a sticky......
BOOST_HAPPENS
http://www.cardomain.com/ride/418842
rigged200 is offline   Reply With Quote
Old 06-27-2007, 07:50 PM   #4 (permalink)
Zexel
The Boost Bear..Rawr!
Zexel's Avatar
Trader Rating: 38 (98%)
After further research, I had the gasket with the extra hole in the back. I changed it after I found out what I had, along with another problem. Ordered VE headgasket from GregV, and no problems now. Good heads up Dre.
Zexel is offline   Reply With Quote
Old 06-27-2007, 08:23 PM   #5 (permalink)
NissanTuner
I hate 240sx owners
nice info, thanks dre
Raze: To destory, demolish, obliterate.
Project RaZe: The ongoing effort to destroy, demolish, and obliterate the competition.
RWD SR20DE 93 240SX Coupe.
Best all Time Quote:
FWD should really be spelled FTW
NissanTuner is offline   Reply With Quote
Old 06-27-2007, 09:52 PM   #6 (permalink)
hybrid D E T
since 2001
I can confirm the cometic part numbers for the VVL that Andreas listed. I have two gaskets here which I know fit. I sent Jason at cometic an OEM VVL gasket for comparison before he shipped them out.
The first is 87mm bore, .030" and MLS. The part number is H1794030S.
The second is 87MM bore, .036" and MLS. The part number is H1794036S.
Maybe it'll help someone out.
Chuck
Shamless Myspace plug
1988 B12 Nissan Sentra SR20DET
1991 240SX SR20DET, Project 240SR
1991 NX2000 SE-R Cup #75
1991 Nissan Sentra SE-R, 24 Hours of Lemons
hybrid D E T is offline   Reply With Quote
Old 06-27-2007, 09:58 PM   #7 (permalink)
cmng
how about GTiR ?
could not find the part no in the catalog as well
but i know they do make it
Arrhh
cmng is offline   Reply With Quote
Old 06-27-2007, 10:00 PM   #8 (permalink)
sr20venosfreak
If I use the gasket with the extra hole on my sr20de will something go wrong cause thats the one I recieved.
sr20venosfreak is offline   Reply With Quote
Old 06-27-2007, 10:33 PM   #9 (permalink)
JUS-det-LUV
dam i got the wrong one and i had it over 30days what a wast of money.and i just found out my $500 plus valvesprings and ti retainers
only cost 325.
JUS-det-LUV is offline   Reply With Quote
Old 06-27-2007, 11:49 PM   #10 (permalink)
DeNismo
VVL Junkie
good info. thanks.
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
Old 07-29-2007, 03:45 PM   #11 (permalink)
Dowve
SE
Can I use a thiker head gasket for a DEt a drill in it the hole for the oil passage ? (If I plan to use sr16ve pistons to lower the compression a little bit)
Dowve is offline   Reply With Quote
Old 10-03-2007, 12:17 PM   #12 (permalink)
AaroNX
Ok so I can't use a VE gasket on my de motor because it has an extra hole?
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 10-08-2007, 02:26 PM   #13 (permalink)
mirrortints
Me likes Big Ol Booties!
I'm pretty sure you can, cause the extra hole is between cylinders 3&4 sticking out (in the VE). Where, this isn't even on a DE...
I ordered a Cometic VE and got that damn S14 HG as well!!!!!!!!!!!!! This was about 8 months ago.
2001 SE Auto...SR20VE-T, info in cardomain page
1993 Infiniti G20...acquired at 214k miles, original motor, going strong
http://www.cardomain.com/ride/1675260
mirrortints is offline   Reply With Quote
Old 06-11-2008, 09:22 AM   #14 (permalink)
DeNismo
VVL Junkie
can we use s14 or s15 gaskets in rnn14? There is a lot on thу e-bay with the mark of rnn14.
http://cgi.ebay.com/ebaymotors/Comet...spagenameZWD1V
must I make extra holes?
