Old 10-11-2007, 09:11 PM   #121 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Trader Rating: -1 (0%)
I bet if I took it to a dealer for an oil change or something all they'd notice is the header.
Installing a VE into an sr20 B15
http://www.sr20forum.com/sr20ve-sr16...e-project.html
zerosin is offline   Reply With Quote
Old 10-11-2007, 09:18 PM   #122 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Kept the EGR temp sensor in the header but the ECU delete should work. I'll have to make a plug for the plug.
Old 10-11-2007, 09:20 PM   #123 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Originally Posted by Calum View Post
That looks really clean! Nice!
Thanks.
Old 10-11-2007, 10:54 PM   #124 (permalink)
RobSE
So lets here some reviews, how do you like it? Does the RPM gauge work? Total sleeper
btw, i would love to see a video of it running through the gears!
2001 Nissan Sentra SE w/PP
Aem Intake, ES MMI, Advance Timing 19*
RobSE is offline   Reply With Quote
Old 10-12-2007, 08:24 AM   #125 (permalink)
zerosin
SR two timer.
zerosin's Avatar
I can't seem to get the Flux Capacitor to kick in, it's not because I can't hit 88 MPH though I can assure you of that.
As soon as the VVL solenoids are hooked up I'll shoot some video.
As for the over-all. Total sleeper is right, I even left the SE 2.0 badge on the back for now. Everything works, all gauges, A/C actually works better, OBDII port, alarm. The alarm light is on constantly while the engine is running, assuming that the immobilizer is no longer working and thinks the car has been stolen. It drives like a champ. Even without the VVL kicking in it out performs the old DE, and this with the TPS still needing to be dialed in from losing about 2V up top.
I can't wait to get the JWT ECU with the old timing maps in this week and get the cams popping next week. This car is so fun already.
Old 10-12-2007, 01:53 PM   #126 (permalink)
KrAsH
Racing Addict
I'm glad it's working out. The sleeper look is fun to have. Seeing people's faces when you keep up with their high end cars in your "stock" SE is priceless
Sorry about not being able to help you out in a timely manner for the MAF connections, but I've been very busy in the last two weeks, because I changed jobs.
What's the matter with your JWT maps? Were you getting the timing hesitation issue between 2k and 3k RPM?
Actually, I may need your help now
How did you get the OBD2 port to work? That's the only thing that is not working for me right now.
Matt
2001 Sentra SE/pp (SR20VE powered)
Trac Racing Depot
KrAsH is offline   Reply With Quote
Old 10-12-2007, 02:04 PM   #127 (permalink)
zerosin
SR two timer.
zerosin's Avatar
No big problems with the current (newer) JWT ECU. Just a little weak down low, feels like it could have a little more punch. The OBDII required just one pin to get it working. I'll take a look at my notes at home tonight.
Old 10-12-2007, 02:30 PM   #128 (permalink)
KrAsH
Racing Addict
Thanks
I was just wondering about the ECU because mine seems to have lost power on the low end too when compared to when I was runing a stock B14 ECU + AFC Neo. It's just an irritant for daily driving, however, because it only appears at low RPM, which is basically not used on the track. I guess I'll be putting it on the dyno early next year, before the racing season starts...
Old 10-12-2007, 03:02 PM   #129 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Originally Posted by KrAsH View Post
Thanks
I was just wondering about the ECU because mine seems to have lost power on the low end too when compared to when I was runing a stock B14 ECU + AFC Neo. I guess I'll be putting it on the dyno early next year, before the racing season starts...
I have an older JWT ECU with the original timing maps coming this week and Calum is having one of his sent as well. Well see what the differences are between them.
Old 10-12-2007, 03:03 PM   #130 (permalink)
zerosin
SR two timer.
zerosin's Avatar
I advanced my timing to 19 degrees for now and that helped a lot with this ECU. Since I'm not popping cams yet I'm not worried about the high end loss from the advancing.
Old 10-12-2007, 09:00 PM   #131 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Here ya go KrAsH:
B14 B15 (with NATS- immobilizer)
001 - Dizzy power transistor 035 - Dizzy power transistor
002 - Ignition coil 036 - Ignition coil
003 - To Tachometer 032 - To Tachometer
004 - ECM relay (coil) 031 - ECM relay (coil)
008 - Fuel pump relay 021 - Fuel pump relay
009 - 048 - Ground
010 - Ground 048 - Ground
014 - Cooling fan relay 012 & 013 - Cooling fan relays 1&2
015 - AC relay 023 - AC relay
018 - MIL 022 - MIL
019 - Ground 057 & 048 - Ground
020 - Ignition switch 041 - Ignition switch
021 - AC thermo control 044 - AC thermo control
022 - Neutral position switch 042 - PNP switch
023 - TPS 092 - TPS
025 - Power steering pressure switch 046 - Power steering pressure switch
026 - Speedometer 086 - Speedometer
038 - Ignition coil 043 - Injectors ground
039 - Ground 108 - Ground
040 - Camshaft position sensor 075 - Camshaft position sensor
041 - Camshaft position sensor 085 - Camshaft position sensor
043 - Ground 058 - Absolute pressure sensor
044 - Camshaft position sensor 075 - Camshaft position sensor
045 - Camshaft position sensor 085 - Camshaft position sensor
046 - Front O2 sensor 062 - Front O2 sensor
047 - MAF 061 - MAF
048 - MAF 073 - MAF
049 - TPS 111 - TPS
050 - Engine coolant temp sensor 058 - Absolute pressure sensor
051 - Engine coolant temp sensor 070 - Engine coolant temp sensor
052 - Rear O2 sensor 063 - Rear O2 sensor
053 - Crankshaft position sensor 065 - Crankshaft position sensor
054 - Knock sensor 081 - Knock sensor
056 - ECM relay (switch)/CPS 110 - ECM relay (switch)
058 - ECU data link connector (OBD) 115 - ECU data link connector (OBD)
061 - ECM relay (switch)/CPS 112 - MAF/ECM relay (switch)
062 - EGR temp sensor 072 - EGR temp sensor
063 - Intake air temp sensor 064 - Intake air temp sensor
070 - ECM relay (common)/battery+ 067 - NATS IMMU/ignition switch
101 - IACV-ACC valve 006 - IACV-ACC valve
102 - Injector 1 101 - Injector 1
104 - Injector 3 105 - Injector 3
105 - EVAP purge control valve 014 - EVAP purge control valve
106 - Ground 108 - Ground
107 - Injector 2 103 - Injector 2
108 - Rear O2 sensor 003 - Rear O2 sensor
109 - Injector 4 107 - Injector 4
111 - Ground 106 - Ground/dizzy power transistor
112 - Ground 106 - Ground/dizzy power transistor
113 - ECM relay (common)/battery+ 067 - NATS IMMU/ignition switch
115 - Front O2 sensor 004 - Front O2 sensor
118 - Ground 108 - Ground
This is based off of JGY's somewhat non-descriptive map, though very useful. I've added for OBDII and EVAP purge control.
I will make a more detailed map for those to come. 058 to 115 is what you are looking for. The other pins for the OBDII connector were already connected in JGY's map.
Old 10-16-2007, 02:28 PM   #132 (permalink)
KrAsH
Racing Addict
Hmm... I had done exactly that, and my reader/scan tool still doesn't work. I wonder if it's the reader that broke. I'll have to try it out with another reader, I guess.
Thanks for the info.
Old 10-21-2007, 03:21 PM   #133 (permalink)
zerosin
SR two timer.
zerosin's Avatar
Installed the MSD 8969 so that makes a complete swap.
Backed the timing off to just over 15 degrees too.
Old 11-20-2007, 01:09 PM   #134 (permalink)
RobSE
Wow, that looks so fresh and so clean! So how do you like the new motor? Do you have an aftermarket exhaust? Lets see some more pics!!!!!
Old 11-21-2007, 12:07 PM   #135 (permalink)
zerosin
SR two timer.
zerosin's Avatar
I'm digging it a lot. I think the ECU could be refined but it's a pretty good base tune over all. I'm working on a TPS voltage issue but that's not causing me much hassle at the moment.
I have an SSAC header with 2.5" midpipe and HKS catback that was supposed to be about 2 3/8" but the mandrel bends actually reduce a little more than that. I put a 24"x4" Magnaflow resonator in there too but kept the HKS mini resonator. Sounds good but it is a little too boomy until 4k RPM. After that it gets a nice almost quiet roar. I want to have a nice 2.5" cat back with a G35 or some other twin loop style muffler to reduce the boom a bit.
It is fast and quick.
Old 11-21-2007, 09:24 PM   #136 (permalink)
KrAsH
Racing Addict
Yeah, I've actually measured my HKS exhaust with proper tools, and it measured just over 2 1/8 right after the resonator.
Glad you're enjoying the VE
Old 11-22-2007, 05:24 AM   #137 (permalink)
Ricer_X_01
15642uner
Ricer_X_01's Avatar
the hks super dragger for the 00-01 se is 2.36" or 60mm
Ricer_X_01 is offline   Reply With Quote
Old 11-22-2007, 10:30 AM   #138 (permalink)
zerosin
SR two timer.
zerosin's Avatar
3/8" is .375, just a rough measurement for the standard folks here.
Though at the bends it is much closer to 2", it's not 2.36" all the way through.
The way they advertise on their site it sounds like the whole thing is stainless though the pipes are painted. can't see that they're stainless or not but why do you need to paint st
