Old 07-02-2002, 05:29 AM   #1 (permalink)
You're my boy blu!!!!
rpm switches?
I have a quick question, I see a lot of ve owners using rpm switches. Has anyone considered using a vtec controller, i know it is intended for hondas, but dosen't in a since activate the vtec switch over point the same way the ve switch over point should work? Just wondering.
92 SE-R-wish i had it still
87 Mitsu Starion-Gone
94 Integra-Gone
99 Alantic Blue Mustang GT- 4.6 SOHC V8, Tremec 3650, 8.8 Rear, Ceramic Flowtech LT's with Matching X-pipe with Pypes Cats, Spintech side exit, 18X9, 18X10 Bullitt Repilcas, M&M C&C plates, Eibach Prokit springs,03-04 Cobra front brakes,Steeda bumpsteer kit, Steeda X2 ball joints,Prothane offset rack bushings, K&N drop in filter
camoser is offline   Reply With Quote
Old 07-03-2002, 01:17 AM   #2 (permalink)
爆走
from what i have heard a honda vtec controller will cause some interference with the nissan ecu somehow. most of the vtec controllers are for sinlge stage vtec. i suppose you could get an i-vtec controler for the rsx if they make one. the vtec controllers are also expensive, with rpm switches being fairly reasonable. i am going to be building a prototype vvl controller on my return to the US and see how it works on my car should be fairly inexpensive if it works. it will be two stage and adjustable.
Old 07-03-2002, 08:58 AM   #3 (permalink)
This is actually the only part of my swap that I haven't bought yet. I like the MSD switches but the pills are in 200rpm increments and then in 1000 rpm sets ie: 5000,5200-5800. I can' decide which to get. Plus they also have the variable on that cost more.
Steve
06 G35 6MT
Old 07-05-2002, 02:27 AM   #4 (permalink)
爆走
steve i will build you one if it works looks like it should be chea for the whole thing if you like it you can send me the money otherwise just send it back to me. completely variavle adjustment, two stage, and i might include a shift light.
Old 07-05-2002, 08:45 AM   #5 (permalink)
That sounds great. When do you get back from Japan? My VE should be here soon. BTW, Three things I have always wished I could do. 1) Weld 2) Rebuild a transmission 3) Make Electrical components. Quess what I'm doing this weekend. Putting a Quaife into a tranny I have in the garage. One of these days I am going to take some classes.
Old 07-05-2002, 09:07 AM   #6 (permalink)
爆走
i will be back july 11. becarefull with that quiafe its a little tricky. i will keep you posted. shouldnt take me too long its pretty easy and i hope it goes well. i have messed with electronics for a long time, but i should put that knowledge to use i guess.
Old 07-05-2002, 09:22 AM   #7 (permalink)
I have my trusty FSM and some good written directions that Ben Davis gave me when I bought the Quaife. If I feel like I am over my head I have a Nissan Mechanic who I can pay to put it in. Ben’s directions are pretty good. Also, He said that if you pay attention to how it feels when moving the lever and how the gears spin before you take it apart and then it feels the same after the install, you are good to go.
Do you think that cam controller could be done before my install on the 20th? This is very generous of you to offer this.
Thanks
Old 07-05-2002, 10:38 PM   #8 (permalink)
爆走
i might be able to get you one that you have to adjust with a screwdriver...it wont be pretty. but it should work. i will let you know as some of the parts may have to be ordered.
Old 07-05-2002, 11:02 PM   #9 (permalink)
I would prefer that screwdriver adjustment. Less chance of the state inspector messing with something he shouldn't. Let me know if you think you can make it. I can probably get the MSD parts pretty quick so I will wait till I hear from you after you get back. I love the idea of the infinite adjustment.
