Old 02-10-2008, 08:24 PM   #1 (permalink)
Trader Rating: 16 (100%)
VE Dyno!
Dyno Results in!
Here's my current setup:
20VE
N1s
CS Gears +5/-5
GSpec Pulley
Fidanza Flywheel
BC Springs
SSAC
Calum
4 Bar
3" Exhaust
Outlaw Spacers
3" CAI
DE TB
DE MAF
BTW, switching both cams at 4500 RPM.
So based on a 10% "calibration factor" between Mustang and Dynojet, I'm safely over the 200hp bar with the engine. I think the AFR is pretty close, so all I have left to tweak is header ($$$$ - maybe I'll build one for fun...), Maxima MAF (that may fix the high RPM tail off in torque), and timing/ECU tuning.
Any idea? I was running a CAI so the short ram intake has been said to give more power, again more up top where I need to fill out my torque curve and make more max HP.
I think without getting a freak header, I should be able to get another 5-10 HP right?
Vid:
_SHig
SHigSpeed is offline   Reply With Quote
Old 02-10-2008, 08:59 PM   #2 (permalink)
Nice vid, do you have a resonator? Mine sounds almost identical. I take it their was a large difference in sound with the N1's?
Thanks,
Dudeman
Looking for a shell
1991 SE-R
Old 02-10-2008, 09:05 PM   #3 (permalink)
No cat (2.5" tubed cat shell), yes Dynomax 18" (?) resonator and JIC Ti muffler uncorked.
I've never run anything BUT the N1s so I wouldn't know. Spoiled I guess!
Here's my build blog on G20.net:
http://www.g20.net/forum/showthread.php?t=63780
_SHig
Old 02-11-2008, 06:49 AM   #4 (permalink)
Always Different !
That ~6500 to 7600rpm dip in the torque curve mirrors the AFR trend to richen up. EXACTLY the same rpm band that my 1.6 with N1 Cams on carburettors is richening up. The curves look near identical. Just for comparrison I have my AFRs pretty tight between 12.8 and 13.2:1 so it's richer than yours, but interestingly that the EFI and Carbs are responding to the N1 Cams in the same way.
Also with the +5 / -5 timing your power curve should extend past 8300rpm. Dialed straight up on the 1.6 the N1s are making power straight up to 8600rpm before fallling off.
I know alot has been said for 3in, but do you think that smaller may be better?
BIGtoe
Beware of, "Repetitious Mupitism"
bigtoe is offline   Reply With Quote
Old 02-11-2008, 09:41 PM   #5 (permalink)
the proof wizard
Trader Rating: 26 (100%)
between the local mustang dyno vs the local dynojet. ive seen a 5% difference in whp. i think on a dynojet your motot will do 185whp. that big jump after 7.5k is just from lifting off the throttle..
12sec NA
Old 02-11-2008, 09:48 PM   #6 (permalink)
Guanaco Tuner
Might be different here.. My turbo car made 60 less hp than it did on a local dynojet (with more mods this time).
Old 02-11-2008, 09:58 PM   #7 (permalink)
The car pulled 187.3 after calibrations (on the non-chart page) so I'm easily pushing the 200 WHP dynojet. The jump at 7.5 can't be lift though '*** I floored it until the 9k rev cut.
_SHig
Old 02-11-2008, 09:59 PM   #8 (permalink)
The car pulled 187.3 after calibrations (on the non-chart page) so I'm easily pushing the 200 WHP dynojet. The jump at 7.5 can't be lift though because I floored it until the 9k rev cut.
_SHig
Old 02-11-2008, 11:05 PM   #9 (permalink)
the proof wizard
so what are you using for the 9k rev cut?
Old 02-11-2008, 11:39 PM   #10 (permalink)
It's a 2-stage bike rev limiter, but works great for this. It's a "soft" cut that gradually kills spark. Probably not good for extended use on a car with a cat. May cause meltage!
_SHig
Old 02-11-2008, 11:53 PM   #11 (permalink)
the proof wizard
damn that is nice, any info on it?
Old 02-11-2008, 11:59 PM   #12 (permalink)
Got it cheap on Ebay. I've been wanting to crack it open so I can tweak down the high limit knob so I can use it in true dual stage setting. As is, I'm currently just using the low knob full time jumpering out the clutch pedal switch.
More info at http://www.dynaonline.com.
_SHig
Old 02-12-2008, 12:03 AM   #13 (permalink)
Buy it cheap here! http://cgi.ebay.com/ebaymotors/Dyna-...spagenameZWDVW
Bid quick! Perfect timing...
_SHig
Old 02-12-2008, 05:57 AM   #14 (permalink)
SRVVL-IAN
Nice...vid
benzene is offline   Reply With Quote
Old 02-12-2008, 12:26 PM   #15 (permalink)
Dammit, that limiter went for $67. I should have bought it for my new VE project.
Oh well, I guess I can live with an ECU rev cut at 8K for now...
_SHig
Old 02-20-2008, 01:34 PM   #16 (permalink)
Originally Posted by SHigSpeed View Post
Dyno Results in!
20VE
N1s
CS Gears +5/-5
GSpec Pulley
Fidanza Flywheel
BC Springs
SSAC
Calum
4 Bar
3" Exhaust
Outlaw Spacers
3" CAI
DE TB
DE MAF
What does "4 Bar" mean?
Krist is offline   Reply With Quote
Old 02-20-2008, 01:47 PM   #17 (permalink)
Auto to manual in progres
4 bar = 59psi fuel
vdubya63 is offline   Reply With Quote
Old 02-20-2008, 10:30 PM   #18 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
I think you are in the range where an N60 MAF will significantly add power. Not much, but it will show clearly.
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
Old 02-20-2008, 11:04 PM   #19 (permalink)
Hope so. I installed one this week and have a Calum BIN to match, but I'm not sure if the file is good or not yet. I also went from CAI to WAI with a BLOX intake velocity stack:
http://www.g20.net/forum/showthread.php?t=63780&page=28
Butt dyno says nothing noticeable, but it has been wet around here, and it may be hard to notice 1% or 2% over 200 hp.
_SHig
Old 03-14-2008, 02:44 AM   #20 (permalink)
Sounds fierce at the lobe switch. Is this an E model?
