Originally Posted by POC
So i wont need to notch the N1 pistons?
The SR20VE piston is on the left and the SR16VE piston on the right. Look to the lower left of the skirt and you will see the diffrence. The SR20VE has to clear the oil squirters because of the storke. Double check your piston when you take it out and make sure it is notched.
Sr20VE on left SR16VE on right. Note the dome on the SR16 vs the SR20.
