it's not LSD, so it's not off the N1 engine, the speed sensor is cable type not electronic, it came off a older model vehicle, either JDM P10 premera or U13 bluebird.
U13 Bluebird. P10 uses a 32 type tranny and are also cable
Im not sure what its from but its deff an rs5f50a.
I know a32/a33 maximas with the 2.0ltr v6 engine had this gearbox (pretty common car) not sure on the bellhousing though...... Also maybe u12 bluebirds.
The 3.0ltr maxima got it aswell but its rare and uses the lower final drive.
Yep, its a u13 50 series box, open diff. You could make it work, but would need custom mounts. They are maybe 5 to 10% stronger than a 32 box, but thats a big maybe. Being open diff, it would break traction before it breaks the box.
There must be a few p11's over in Japan that have had manual conversions done, this is the 2nd i have seen posted on the net of a sr20ve with a manual trans still bolted to it.
