Old 02-25-2008, 01:07 AM   #1 (permalink)
2001 B15Ve+N
Some questions
Hello
1) just wondering what thickness of head gasket i should get. I am install cams (n1's), and valve springs and i am removing the head. i wanna raise the compress a bit but with having any clearance problems...
2) what would be a good cam gear setting for N1s with valve springs is it still
+5/-5 or no. I will be reeving to RPM
Thanks for the help
cheers
rob
Rob_96 is offline   Reply With Quote
Old 03-08-2008, 12:27 PM   #2 (permalink)
2001 B15Ve+N
? anyknow what the compression will be with thinner head gasket
Old 03-11-2008, 09:51 PM   #3 (permalink)
I cruise @ your top speed
Bumpppppy
-Ryan-
'91 Hardtop NX2000-SR20VE
Originally Posted by 1NonlyDave
What in the world do you have done to your SE-R? Has to be quite alot to beat the K20Z3 that bad.
Originally Posted by mannytheman1257
its the k20s nightmare...VVL lol
NismoSR20 is offline   Reply With Quote
Old 03-11-2008, 10:15 PM   #4 (permalink)
Sorry man couldn't tell you a hundred percent, but I know with the cams dialed to +5 -5 its a tight fit, best check over at the dash if no one can give you a for sure answer. I know there has been allot of talk about headgaskets in the past month over there too, not sure if the threads are over here as well. I will try and check around too, as I am interested in the options, its on allot of people minds. I also know the 16ve pistons are an option as well, and they would allow for some more clearance.
GL
Dudeman
Looking for a shell
1991 SE-R
