Old 02-27-2008, 01:26 AM   #1 (permalink)
VZR SR16VE
wiring solenoids to engage at same time ???
hey guys,
have any of you guys ever wired the two solenoids wire together to get the two cams to kick in at once ??? what wiring needs to be done,
ive search to see if theres any post, but cant seem to find any
if there already is a post please forward it
thanks
danii is offline   Reply With Quote
Old 02-27-2008, 10:17 AM   #2 (permalink)
Is an SE-R/VE a VE-R?
Per Miko's direction, I wired mine together via an MSD 8207 switching the ground. Set at 4600, again per Miko for this particular setup. It kinda explodes - spins the tires in 1st when it hits the cams.
'93 B13, etc.
do it over and over again?
Old 02-27-2008, 10:52 AM   #3 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
I used an MSD 8969. Here is the archaic wiring diagram I made at some point:
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 02-27-2008, 12:08 PM   #4 (permalink)
Technician and Enthusiast
I had mine switched on the power side before. I just hooked two wires together to ground, and had the mss power the solenoids via one switch so I could use the other switch for other things. It worked well, the cams seemed to hit a lot harder, but there was a slight dip in the powerband.
Coheed is offline   Reply With Quote
Old 02-27-2008, 12:40 PM   #5 (permalink)
SR20VE powered P11 GT
The two wire from the actuatures into the ecu are earth wires. Simple disconnect then from the ecu, link then together and run theose your switching device. No rocket science involved....
Old 02-27-2008, 07:09 PM   #6 (permalink)
VZR SR16VE
nice, thanks heaps guys
thanks for the diagram too NismoSER
Old 02-27-2008, 07:26 PM   #7 (permalink)
VZR SR16VE
just out of curiosity, whats the MSD 8969, sorry im abit noob at this
Old 02-28-2008, 01:16 PM   #8 (permalink)
Trader Rating: 102 (100%)
Its an rpm activated switch.
http://www.msdignition.com/rpm_14.htm
