I've got a problem.
1. I have a Gti-r. It is a sr20det in it. cp pistons. (2.1l displacement). The crank is stock and damaged. If I use a larger stroke crank, e.g. 90-91 mm stroke, what type (size) of gasket must I use?
2. I've got a sr20vet. It is stock. How thin must be a gasket to use 90-91 mm stroke crank in it?
3. How much revs/min does the bc STrOCKER KIT can handle? (600 hp). The Lotus Engeneering tool says that the 6000 rpm is the maximum for the 20m/s piston speed. Can the BC stroker kit handle more than 6000 rpm.
 Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
