Old 03-12-2008, 06:50 AM   #1 (permalink)
VE Cam Switching Conditions by Nissan
Yeah I was wondering on how Nissan do the switching on the cams with the original VE ECU. Is it solely done on RPM or does the Throttle position come into it? I saw this about setting up a Greddy MSS and it made me wonder.
If someone can confirm if its solely done on RPM or RPM&TP it would be appreciated
StrikeEngine is offline   Reply With Quote
Old 03-12-2008, 04:32 PM   #2 (permalink)
SR20VE powered P11 GT
Not sure how the ecu does it, but it would be better to use RPM and TPS signals as that way it would stop the cams popping on down shifts...
Old 03-13-2008, 02:04 PM   #3 (permalink)
Tps voltage
does tps voltage make a difference...what is the best voltage to set the cams to come in and off...??? pls reply
khegan is offline   Reply With Quote
Old 03-17-2008, 09:52 AM   #4 (permalink)
CAR SLÜT
I set mine so that throttle position and engine load are taken into account. It helps maximise part throttle torque. I also stop VVL from activating when the engine is cold.
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 03-17-2008, 10:49 AM   #5 (permalink)
Trader Rating: 16 (100%)
Did you build a comparator circuit and plug it into the TPS output, or some sort of mechanical switch?
_SHig
SHigSpeed is offline   Reply With Quote
Old 03-23-2008, 02:24 PM   #6 (permalink)
SE-R GREEK
He uses a Bikirom board and its SW can trigger based on multiple conditions.
Nissan ECU triggers on RPM only.
