Old 03-17-2008, 01:57 PM   #1 (permalink)
Always Dubbin'
vvl headgasket question
well i pm'd a few people and got no response to my question, so i figured i'd post up and see if anyone could chime in.
i want the best of both worlds with the motor i want to build, vvl head w/det bottom end.
i was thinking if i could use the stock de bottom end, but i plan on running a t3/t4 so lower compression the better i guess. my question is to setup the vvl head (i read luis headswap multiple times) around what compression will i yeild with a det block with stock 8.5:1 pistons, a vvl metal headgasket, and a stock unported vvl head.
this will be an ongoing motor build for some time as money gets stored away for it.
Coming soon: Project Daily
GT25 powered Volkswagen GTI ~ 275whp on stock internals
92serturbo is offline   Reply With Quote
Old 03-17-2008, 02:38 PM   #2 (permalink)
Enemy of the stupid
wasn't it 9.1:1? or somewhere around there. You could prob buy some VET pistons from Greg V and throw them into your motor unless you don't plan on cracking the bottom end open. You could use the DE block too and just tune it right around the compression.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 03-17-2008, 03:14 PM   #3 (permalink)
Always Dubbin'
i think as long as its below 9.5:1 i should be okay. i dont really want to open up the bottom end unless i really have to.
Old 03-18-2008, 11:30 AM   #4 (permalink)
Technician and Enthusiast
the 8.5:1 pistons make 9.3:1 compression in a VET. It works pretty good for pump gas. I ran 17psi on my vet with this compression ratio in winter with no issues whatsoever. But I have decided to go lower compression for that margin of safety.
Coheed is offline   Reply With Quote
Old 03-20-2008, 11:23 AM   #5 (permalink)
the proof wizard
Trader Rating: 26 (100%)
you could always go with a slightly thicker cometic hg and bring that cr down a little bit.
12sec NA
Old 03-20-2008, 11:35 AM   #6 (permalink)
Always Dubbin'
im thinking of a de block since they have the 8cw crank and basically other than the pistons and oil squirters they are the same. running a little larger than stock HG and the vvl head on it..
my local tuner just made 380 whp on a completely stock de with a t3/to4e at 18psi on a moderate tune.. thing is a beast
Old 03-20-2008, 03:10 PM   #7 (permalink)
SR20DEEEEEP
are you talking about fast spec...
they already blew that car up. didnt last very long
Originally Posted by Shawn B View Post
Then you get pissy, belligerant, and your panties get bunched up when someone, namely me, tries to actually help you with a couple of links?!?
Are you f*cking kidding me?!?
You sir, are an unmitigated selfish, egocentric, self-absorbed, DOUCHEBAG and can go f*ck yourself.
Originally Posted by johnnym View Post
Were you yelling this in your head as you were typing it?
Hit the caps lock buddy
Old 03-20-2008, 03:13 PM   #8 (permalink)
Always Dubbin'
ya i figured travis' car wouldn't last too long.. it was like a bullet from hell ***
