Old 03-21-2008, 07:47 PM   #1 (permalink)
anyone using e-manage ultimate??
Hi, I'm starting projet Infiniti G20 00'.....because 99' are almost unfindable here.
So planning to swap the RR for the VE....and i tought of getting the apexi safc neo because theres a VVL selenoid control but there's no rev limiter control...
As i read on the g-reddy site the E-manage ultimate can control the Rev and speed limiter...
Another advantage is the ultimate can controll VVL selenoids, and can self tune for the base map with a wideband...
Seems to me that for 200$ more bucks than e-manage or safc neo, all those benifits would make if a better candidate for my G...
So anyone can confirm this to me, will this work on the VE?
qctuner is offline   Reply With Quote
Old 03-22-2008, 12:18 AM   #2 (permalink)
Enemy of the stupid
why not a conversion harness? I'm sure someone must make one so you can run the older ECU's.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 03-22-2008, 09:42 AM   #3 (permalink)
Very Very Loud too!
Apexi states that SAFC NEO has the capability to alter the VTEC point for Honda-Accura applications, but what about Nissans? VTEC kicks in together, VVL doesn't! There's also an issue with the speed limiter? Can the SAFC remove the annoying 180km/h limiter?
What would you guys (e-manage users mostly) reccomend? Greddy or Apexi?
Nikiforos-P10 is offline   Reply With Quote
Old 03-22-2008, 08:43 PM   #4 (permalink)
Hi, i think that the single output for the VVL is not that of a big deal since it will be ok(maybe some ponys lost) to wire them in parallel(both on/off).
SAFC cant change the speed/rev limiter but im not shure about the E-Manage ultimate... So anyone knows??????
Old 03-22-2008, 08:49 PM   #5 (permalink)
Yeah, i think ill go on that way.... but the SAFC NEO is still a good idea since ill need a MSD thing to get the VVL working as well.
MSD is about 100-150$ and NEO is about 300$.
So for 200 bucks more i'll definitly go it with for the VVL activation since there are a lot more option on the neo like having more conditions to activate VVL like %of the tps; so if your on 1/4 of the throttle the VVL will not activate for nothing because you just dont need the boost.
