i didnt know where to post this to get the best response, so here it lies.
i am wrappin up my motor build. its kinda frankenstein. port and polished DE head, DET block, a bunch of other stuff including a VE oil pump from gregV.
here is my issue...............
i am having an issue with the ve oil pump.
im wondering if this is a common problem.
it installed fine for the most part. i remember when i installed it months ago, there were some fittament issues that i "worked" out. that concerning the oil pick up tube.
now going to bolt on the upper and lower oil pan, and the scraper tray,
the oil pick up tube is clearly an obstruction again.
do i need to "work" that issue out as well? it would seem so, unless this is a common problem that you have an easy fixture for.
i can maybe post pics if needed. i will have to snap em off though.
does it come down to i just have to "manipulate" it a bit. my understanding was it was a direct bolt on replacement????????????
the bolt pattern is slightly different from the original, so that is not an option.
ideas? i did search, but that returned nothing helpful.
