N1 Cams
CS Cam Gear
SR16 Pistons
Cometic 2.0 Millimeter Head Gasket
SR16 Flywheel
GTIR Intake with 3'' Inlet Plenum
444 CC Injectors
SSAC 2.5'' Headers
2.5'' Mendrel Bent Exhaust free flow
Maxima 3'' Maf
NO more AC compressor
Custom Tune ECU OBD1 (8400 RPM Cutt off)
How did you get the ecu to control the revlmit at 8400? The most I got it too was 8200. Hope you have valve springs because it's going to get nasty if it doesnt hit a limiter at 8400.
The rev limiter was set to 8400 but im planning to shift around 8000 most the time. The ECU was chipped and will be tune soon with a laptop and a wideband
The ecu won't fuel cut at 8400 like it says in the rom. after 8200 it's like no revlimiter. unless it's a VE ecu then I don't know about that.
