Old 03-22-2008, 09:41 PM   #1 (permalink)
need help with me ve!!
did a ve swap got everything hooked up and in. Car turns over, fuel pump works, all the lights in the dash everything works, but no spark at spark plugs. Changed the coil and still no spark. Put new distributor, plugs, plug wires, cap, rotor, ect... I have been chasing wires and tring to figuer this out for 2 weeks now. I'm out of ideas and thoughts.
I'm not getting the single from the ECU to the distriutor moduler. Please let me know what your thoughts are.
jpshumway is offline   Reply With Quote
Old 03-22-2008, 10:10 PM   #2 (permalink)
Have you checked the crankshaft Sensor ?
Chris_200SX_SER is offline   Reply With Quote
Old 03-23-2008, 04:50 AM   #3 (permalink)
SR20VE powered P11 GT
Which dizzy and ecu are you using?
Old 03-23-2008, 06:43 AM   #4 (permalink)
Double check the wires between the dizzy and ecu. Take a look at the wire diagram and pin-out list on the attached link.
VE wire diagram
Old 03-23-2008, 06:20 PM   #5 (permalink)
what is a dizzy? and what should the crankshaft sensors be at? link to wiring diagram dosen't work.
Old 03-23-2008, 06:32 PM   #6 (permalink)
Dizzy is the distributor.
Link works fine from here. Anyway here are the diagrams. Look at ecu pins 22, 30, 31 & 40...
Old 03-23-2008, 06:32 PM   #7 (permalink)
using stock ecu to get it fired up with stock se-r wiring harness. were are the camshaft sensors located?
Old 03-23-2008, 06:33 PM   #8 (permalink)
i put the ve in a 93 b13 se-r 5 speed. does this make a difference?
Old 03-23-2008, 06:38 PM   #9 (permalink)
using a stock sr20de dizzy. Thats what gspec told me to use
Old 03-23-2008, 06:44 PM   #10 (permalink)
The dizzy isn't getting the right signal fron the ecu. you need to swap the four pins around. Pins 22 & 30 need swapping for 31 & 40...
