Old 03-25-2008, 11:07 AM   #1 (permalink)
Hi!
Introducing myself here from Aus!
I have a 1994 Pulsar SSS that came with an sr20de.
Have recently had an sr20ve slotted in, but currently running on the DE ECU until the correct ECU arrives.
The motor has the following:
xforce 4>2>1 extractors
2.5" mandrel exhaust
pod filter
lighter flywheel
apexi safc
We will be running with the std sr20ve ecu until my greddy MSS arrives from japan, and i can get a tunable daughterboard installed.
This will allow me to change the VVL activation, increase the rev limit to about 8000rpm and tune fuel/ignition.
hoping for some good power!
The car also has various suspension modification, and a big set of brakes...
heres a pic of the car
and the brakes compared with std
comments welcome!
Lonewolf1983 is online now   Reply With Quote
Old 03-25-2008, 11:21 AM   #2 (permalink)
Looks awesome, love that car its so unique compared to what I am used to seeing over here, reminds me of a Saab.
GL, and keep going with it you will love it.
Dudeman
Looking for a shell
1991 SE-R
Old 03-25-2008, 11:30 AM   #3 (permalink)
a saab!
haha!
Old 03-28-2008, 08:20 AM   #4 (permalink)
well the ecu is in and solenoids all set up.
had some VVL goodness, then promptly stuffed a heater hose
Old 03-28-2008, 09:10 AM   #5 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
Wow, nice car man. First time I have seen a picture of one of those
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 03-28-2008, 10:49 PM   #6 (permalink)
wow everyday pulsars are unique over there...funny how that works, although the sss is a bit nicer
anyway good to aus repping some ve goodness
ca18 bluebird is offline   Reply With Quote
Old 03-29-2008, 07:01 AM   #7 (permalink)
N14 racer
What calipers and rotors are those?
Slack is offline   Reply With Quote
Old 03-29-2008, 07:28 AM   #8 (permalink)
twin piston c4 corvette calipers (also used on old HSV's)
custom 330mm rotors
goodridge braided lines
Old 03-29-2008, 10:06 AM   #9 (permalink)
SR20VE EXA
you gonna be running the daughterboard + greddy MSS?
EXABOY is offline   Reply With Quote
Old 03-29-2008, 10:41 AM   #10 (permalink)
SR20VE powered P11 GT
Hi mate. Nice looking motor...
Old 03-29-2008, 11:20 AM   #11 (permalink)
correct.
Hopefully have some good results!
Old 03-30-2008, 08:03 AM   #12 (permalink)
SR20VE EXA
why don't you just use the daughterboard to switch the cams itself? it's easy as with the bikirom
Old 03-30-2008, 09:23 AM   #13 (permalink)
dont want to use a bikirom.
I feel the software and support from PLMS/nistune is superior to whats being offered by bikirom.
