Old 03-29-2008, 06:09 PM   #1 (permalink)
How 2 ident older from newer VE??
Anyone knows how to identify the older (180hp) from the newer (200hp) VE???
Any codes, physical differences??
Thanks
qctuner is offline   Reply With Quote
Old 03-29-2008, 06:30 PM   #2 (permalink)
SR20VE powered P11 GT
204bhp SR20VE (it's actually a SR20VET, but there look all but the same)
180bhp SR20VE
Old 03-29-2008, 07:10 PM   #3 (permalink)
i see so ill get the 180hp one... is that the vet of the x-trail prototype???
so there's only one version of the VE n/a engine, right?
Old 03-29-2008, 08:11 PM   #4 (permalink)
No. The range of engines are the SR16VE, SR16VE-N1, SR20VE(180bhp), SR20VE(204bhp) & SR20VET.
Old 03-30-2008, 12:23 AM   #5 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
SR16VE is blue valve cover,
sr16ve n1 has a red valve cover,
sr20ve (187 hp) has a black valve cover,
sr20ve (204 hp) called '20V' (still has 16 valves) has the funky vc with the red "neo vvl" letters and the big nissan hamburger logo,
sr20vet looks like the 20V but it has a sweet turbo hanging off of if.
1992 SE-R 'Fasty' Mods and more mods. Ready for more boost. Soon.
1992 NX 'Peggy' Intake, exhaust, suspension.
Old 03-30-2008, 01:40 AM   #6 (permalink)
vz-r driver
http://www.sr20forum.com/neovvl-guid...ead-first.html
THOR is offline   Reply With Quote
Old 03-30-2008, 05:14 PM   #7 (permalink)
Thank you... so i'd better try to find one with the hamburger logo to get some extra ponys....
Will i be able to run it with a 95'sentra sr20de ecu reprog with calumRT??
Is it the exact same swap (180hp vs 204hp) or there are differences??
Old 03-31-2008, 05:20 AM   #8 (permalink)
Broke Ass
jer_760's Avatar
You can find all of your info by searching
95 200sx
sr20ve
Old 03-31-2008, 11:56 AM   #9 (permalink)
Dont be a bitch, i did my search and there's very little about the physical differences between the 2 VE's.
I'm shure this thread will help many...
Old 03-31-2008, 12:10 PM   #10 (permalink)
!!!!CAUTION!!!!
blurr.rt.by.you's Avatar
Trader Rating: 66 (100%)
I think you should tone down the name calling.
***GARAGE SALE***
http://www.sr20forum.com/mechanical-oem-part-outs/215172-garage-clean-up-sale.html
http://www.sr20forum.com/mechanical-oem-part-outs/217115-more-stuff-sale.html
blurr.rt.by.you is offline   Reply With Quote
Old 03-31-2008, 12:58 PM   #11 (permalink)
Broke Ass
jer_760's Avatar
Wow
Among the differences are valve cover, bigger cams, intake mani, Coil on plug, one solenoid(switches both cams at once), a bigger and MUCH better tubular header, higher comp pistons, 8 counterweight crank, bigger injectors that are top feed instead of side feed, different timing chain and cam gears, etc. I know all of that from reading around this site. Can't be too hard to search for.........
Edit: A 0.08 second search using "20V" and "differences" yielded ALL of these results..
http://www.sr20forum.com/sr20ve-sr16...-20v-ebay.html
http://www.sr20forum.com/sr20ve-sr16...-20v-head.html
http://www.sr20forum.com/sr20ve-sr16...-question.html
http://www.sr20forum.com/sr20ve-sr16...-into-p11.html
http://www.sr20forum.com/sr20ve-sr16...3-22-06-a.html
http://www.sr20forum.com/sr20ve-sr16...0v-sr20ve.html
http://www.sr20forum.com/sr20ve-sr16...-hp-motor.html
http://www.sr20forum.com/sr20ve-sr16...-info-20v.html
All the info you could want and more, by clicking the search button. I could have found plenty more if I took more time to look, but that's your job now isn't it?
Old 03-31-2008, 01:10 PM   #12 (permalink)
Your dead Twinkie
Hey relax holmes. There's no need for name calling. This stuff gets answered over and over. That's all.
It should prove very difficult for you to get a 20V. If you do find a source share the info.
You will need a different throttle body for the 20V as well because its electronic. Most people opt for the N1
