i've done a recent upgrading from the sr16ve to a 2 litre machine, after 3 years running the sr16.
running in at the moment.
but i've found out the torquey part increased fair a bit.
yet to dyno due to the run-in session.
here's the spec:
sr16ve base engine
stroker kit from sr20de
conrod of sr20's
cometic head metal gasket
racing main bearings from australia's Tasmania (can’t remember the brand)
exedy clutch system
adjustable cam gears
sr16ve's stock cam
sr16ve's pistons, skimmed off 1mm.
upgrade injectors, from sr20det’s
port n polish head
teflon intake plenum gasket(i think the term was right)
jasma approved exhaust header
apexi's rsm
Greddy's e-manage piggyback
pivot shift light
here's the spec:
sr16ve base engine
stroker kit from sr20de conrod of sr20's
exedy clutch system
sr16ve's stock cam
port n polish head
apexi's rsm
pivot shift light
What makes up the stroker kit?
what rods did u use? de or ve
what other pistons can be sued instead of shaving the sr16ve piston?
What ecu are u using with the greddy? 16ve or 20ve?
What is ur new rev limit set at, even *** i know u r still running in motor?
Does the apexi rsm take out the speed cut?
Looking 2 do a similar project in the near future. Presently running a sr16ve and loving it so far.
Tanx.
Peace
2000 Sr20ve Powered Pulsar VZ-R
SR16ve Cams & Ecu, Greddy Emanage (Blue), Apexi RSM (SCD), 60mm Exhaust, JWT Pop Charger Air filter, Tein HA coilovers, 15" Wheels, ACT 6 Pad Sprung Center Clutch w/ Heavy Duty P/Plate, Prothane Motor Mounts. 175whp, 134ft-lb Torque, Top speed 140mph (so far) To come: Noise!
Nice spec, im still planning this for my car but will be very like yours but i will be starting with an SR16ve N1 as my base!
List:
SR20 eagle rods (lighter than standard)
SR20VE crank 4 cw (lighter than 8cw)
Fidanza lightweight flywheel
GSpec pulleys
Upgrade first 4 injectors(what did you use?)
Did you run into any prob with fuel pressure, upgrade fuell pump?
ECU wise i was thinking central 20 daughter board(or similar any suggestions??) or a Greddy emanage, how did you find the emanage, can you alter the speed limiter?
Pistons not too sure was thinking of using the sr20ve pistons which give a 10.3:1 in sr20ve so i need someone to help me work out the cr they'll give with an N1 head, i think the only difference is N1 head is shaved 1mm. Can someone help me with this???
I want to be running very close to 12:1 so was thinking of gettin a custom forged piston to lighten everything up again.
a used crankshaft from sr20DE, not from DET's.
sr20DE's
i suppose forge piston from lots of other brand. my mechanic blew a couple of sr16ve engine till they succeded the r n d. he mentioned higher compression by shaving 1mm from the stock sr16's. to get a 12.8 : 1.
stock 16ve's, + Greddy's e-manage
8200rpm, follows back the stock sr16's.
yes, i had a test run on straight, reached 7k rpm on fifth gear, on stock sr16's gearbox ratio.
List:
GSpec pulleys
List:
- wow! great stuff.
- wow! great stuff.
GSpec pulleys
- my next upgrading.
- i m running on sr20det's injectors.
- so far so good, fuel pump upgraded to bosch's.
- nope, e-manage only alter timing control, and air fuel, + the solenoid for neo's. might be other function, i m not too sure.
- mate, u better check out on this, N1 is a very rare engine. i'll try n check out this from my mechanic, they might know, they only deals with nissan sr series.
- i m not sure of this, i was told my compression is now at 12.8 : 1. is that high?
You say sr20det injectors, off which model? S13,S14?
What litre bosch fuel pump is it?
The e-manage controls the solenoid for the neo, have you both cams kicking at same point or can the emanage control 2 points? What model e-manage did you go for?
That would be great if you could check out the what piston i should get. Your running great CR, high enough for plenty of power! I've read that anything below 13:1 is safe for street fuel.
Anything between 12-13:1 is what i want. Standard N1 is 11.8:1 so at least that anyway!!
- it's from a s13 sr20det's silvia's
- i am so sorry mate, i am not sure. it was replaced long ago. but it's sufficient for the new set up now.
- both cams kicked in at the same time. i think it can control at 2 points as well, but the tuner told me sort of useless. i'll show you the dyno pic. the standard blue colour version, not the e-manage ultimate.
- okay, i'll get my mechanic to check it out.
^^^ Thats a really good figure, so i'd be looking at least 200 whell hp from N1 setup.
I'd appreciate it if you ask your mechanic about the cr of the N1 piston.
hey mate,
asked them, and no one knows, cause they have only sort out a N1's exhaust issue once. no other comments on the N1 version as they have not mod or up stroked a N1 before.
what they commented on the N1 was the lack of torque, compared to the ones they've modded from sr16ve to 2L base.
i am so sorry, can't get you an answer to it!
ohh, i met them earlier today, they request me for the removal of center muffler, re-tune to sort the detonation issue at high rev, i should be getting +-200fwhp. wow, that's beyond me estimates!
cheers bro!
ahh, i think i can recall as well. i was about to get it from you, when my friend gave me a cometic's. so, it's all good. anyway, i will give you a ring for a few drinks in KL then.
cheers!
