Old 03-31-2008, 09:06 AM   #1 (permalink)
POC
Sr20ve header fit sr16ve
As above will an sr20ve header fit an sr16ve engine????
Thanks
POC is offline   Reply With Quote
Old 03-31-2008, 09:37 AM   #2 (permalink)
Enemy of the stupid
Thanks
To find this out you have to know what the difference between the 2 motors are? one is a 2.0 the other 1.6. How do you make a SR16 to a SR20?
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 03-31-2008, 09:47 AM   #3 (permalink)
POC
Just the stroke is shorter! crank, rods and pistons are different bu the bore is the same on both 86mm.
Old 03-31-2008, 09:53 AM   #4 (permalink)
Enemy of the stupid
Yup there the same motors just different stroke and cranks. Cams and everything else will change over.
Old 03-31-2008, 01:04 PM   #5 (permalink)
vzr- sr16ve
Yes it does fit 100%,i had a fuji on my Vz-R.
I've read that a sr20de one will fit too but it needs to be port matched.
lucino vzr 1 is offline   Reply With Quote
Old 03-31-2008, 01:20 PM   #6 (permalink)
hi there,
i've just turn my sr16ve into a 2 litre system. it worked, and i m running in now, probably dyno this week when got time for that.
lschew is offline   Reply With Quote
